02-06-2024, 06:46 PM | #1 |
Rep 111
Are composite or plastic engine parts that bad?
Nearly every automaker (not just BMW!) is using composite materials (fiberglass reinforced thermoset plastic) instead of cast aluminum for certain parts, especially valve covers and cooling system parts.
VW/Audi cars are known for those composite oil pans that crack easily, BMWs are known for composite cooling system parts that leak, even Toyota, a brand known for reliable cars, is using composite valve covers and cooling system parts. In infrastructure, plastic and composite materials are used for everything from water and gas mains to high voltage utility pole insulators (instead of ceramic). Modern materials can be strong, lightweight, flexible, and corrosion resistant. So, are plastic auto parts a bad thing? Or is it just another "they don't build them like they used to" thing from boomers? |
02-06-2024, 10:33 PM | #3 |
Rep 7,483
02-07-2024, 05:49 AM | #4 |
Rep 2,449
Drives: 9Y0 Cayenne S
Is this a chatbot thread?
02-07-2024, 08:01 AM | #5 |
The Seeker
14957
Rep 3,685
For the consumer; yes, they're junk, and don't hold up over heat/time.
For the manufacturer; no, they're junk, and don't hold up over heat/time. Always remember that cars are engineered to be a multi-year source of income for a brand through parts, and labor. The vehicle needs to survive, but it has to nickel and dime you as it gets older. In the case of brands like BMW, Merc, Aston, etc, they need to cause the 3rd owner to become a mechanic to be able to afford to keep it on the road. |
spicyB4890.00 Donatello.1231.50 |
02-07-2024, 11:26 AM | #6 | |
Rep 111
02-07-2024, 12:38 PM | #7 |
Rep 921
I needed a new palstic gas tank and valve cover for my 2018 M3. I've never had to replace either of those parts in any of my previous 70 cars. Luckily I have a 3rd party extended warranty as it has covered almost $7k in these repairs the past five months.
This plastic shit is crap.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
02-07-2024, 01:25 PM | #9 |
The Seeker
14957
Rep 3,685
Is it now that I should remind you that Toyota isn't infallible? That they have many engine oil issues causing the need for rebuilds at 90-150K? Do a little research, they make mistakes.
Donatello.1231.50 chris7197545.50 |
02-07-2024, 01:31 PM | #10 |
Rep 2,985
I don't think in most cases they are bad but some manufactures struggle with sealing the plastic parts to metal surfaces. Honda hasn't been able to design a plastic valve cover that doesn't leak oil on their turbo 4 cylinder engines. VAG hasn't been able to make a plastic water pump or thermostat housing that doesn't leak coolant for a good decade. I think they work better on parts like intakes as with 3D printing they can now make intakes that are lighter and flow much better than cast aluminum. In general most engine bays today are filled with plastic and cars today are as reliable as they have ever been so I don't think it's much to get concerned about.
02-07-2024, 02:35 PM | #11 |
Rep 5,479
In most cases, no, it's not a problem. Plastic these days is pretty robust. Though, there are some parts that shouldn't be plastic, especially those in high heat, high stress areas, and/or not easily accessible areas. Engineers should know better.
The old mechanics that bitch about this stuff and talk about the glory days of when everything was "metal" seem to forget that cars back in the 50s, 60s, and 70s were generally looked upon as disposable. People bought new cars every 1 to 5 years and most cars rusted out within 7-8 years if they lived in an area with salt treated roads. In general, people own their cars far longer longer and cars in stay on the road longer as well. Cars are also far more reliable than they've ever been, all things considered. I have little sympathy when people bitch that their 10+ year old car has developed a rash of issues. Stuff wears out over time, regardless of mileage. The reality is people have gotten used to how reliable their cars are and tend to loose their mind when they actually have to make some repairs. Cooling systems, regardless if they are metal, plastic, rubber, etc. are under a ton of stress. It's not odd that a lot of cooling system parts may need to be replaced at 10-15 years. No manufacturer is immune to this. It was like this in the 1950-1990s too.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
02-07-2024, 02:52 PM | #12 | |
Rep 111
02-07-2024, 02:53 PM | #13 | |
Rep 111
02-07-2024, 02:54 PM | #14 |
Rep 111
Nope, I know that Toyotas have plenty of problems too. I think their reputation for reliability came from a few models that have that "refuse to die" reputation, but they will need maintenance and repairs just like any other car.
02-07-2024, 03:18 PM | #15 | |
The Seeker
14957
Rep 3,685
If they're going to sell me their products that way, I'm going to hold them to it. Now, if they didn't sell it that way, if they didn't play the reliability/longevity card it'd be different, but they do, and are therefore responsible for negative outcomes if I've done all my service. |
murderspice933.50 |
02-07-2024, 03:23 PM | #16 |
Rep 142
The problem isn’t the plastic, it’s designing that same plastic part in the same way we built aluminum products.
Plastic is soft, ages and distorts over time and generally needs far more ribs/gussets and additional material for it to compete with metal. Trying to save weight where you shouldn’t is the engineering issue, I should never have to replace a $500 valve cover because it cracked or warped from age. End of story. |
///MPhatic14956.50 lakefront598.50 |
02-07-2024, 03:28 PM | #17 |
Rep 630
Don't get me started. Nowadays cars manufactures are switching to soy based insulation wire to wiring their cars. Easy to say from the car manufactures to keep our planet green. Very expensive repair for car owners to fix the damage from rodents chewing through the insulation of the wiring.
02-07-2024, 03:38 PM | #18 | |
Rep 111
Grüne? Nein danke! |
eugenebmw1958.50 |
02-07-2024, 03:55 PM | #19 |
Rep 630
Exactly. End up we are producing more wastes to our planet and we have less money in our pockets.
02-07-2024, 05:54 PM | #20 |
Rep 2,449
02-07-2024, 07:46 PM | #21 |
How's My Driving?
1232
Rep 1,057
The plastic crap on my E90 335xi was a joke. Plastic is bad & doesn't belong in a lot of places.
2018 Charger Hellcat
2019 Miata 30th Anniversary 2021 CX-5 Signature 2009 Mazda6 |
02-07-2024, 10:36 PM | #22 | |
Rep 5,479
chris7197545.50 |
