05-26-2015, 03:51 PM | #1 |
Rep 36
Programming new TPMS sensors - coding
Hello,
I've been searching the web for an answer to my problem but I haven't found anything that helps. I installed a second set of wheels on my car last week with brand new TPMS sensors. I reset the system and my car is reading the new sensors fine, all wheels display green on my screen. My problem is that I had my car coded so it used to display PSI and temperature per tire, now it shows those details as blank. I coded my car again to stop displaying PSI and temp, and then coded it again hoping for the system to display the details for the new sensors, but same results, all I see are the "PSI" and "F" symbols, no numbers. I scanned my sensors thinking that they might be malfunctioning, even though the car displays all wheels green, and the scanner shows each wheel's ID, temp, PSI, and frequency just fine. I want to see PSI per wheel again, I have all four sensors' IDs, how do I get them programmed in the car? Is this something that I can do through coding? Thank you. |
05-29-2015, 11:28 AM | #4 |
Rep 36
Thanks guys for the info. I tried PMing v12 but it seems like he's been banned from the forum, I can't even leave a visitor's message on his profile page. Hopefully I have better luck with Shawn.
06-06-2016, 02:11 PM | #5 |
Rep 137
I need help on this one
I have a new set of wheels that I want to install on my 2013 535ix. The new set of wheels has a new set of 4 tpms sensors. I need to know how I can pair the tpms sensors to the car ? |
06-09-2016, 12:51 AM | #6 | |
Plenipotentiary
2614
Rep 3,046
And I just noticed this was a resurrected thread..... |
Tags |
tpms coding |
