      08-02-2016, 07:42 AM   #1
SakM_5
Drives: Panamera Turbo S
downpipe install questions
I have a set of AMS catless downpipes I plan on installing this week. Is there anyone on here that has done the install? how long does it take? on a scale of 1-5 how hard was it? also, did you change the gaskets? if so, between the turbo and dp or between the dp and exhaust?
Any help would be appreciated! Thanks
      08-02-2016, 08:47 AM   #2
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
time=2 hours to cool down + 2 hours to uninstall and install new =4 hrs
scale=2.5
its recommended to change the the gaskets my car only had 4k miles on it and the gaskets were in good shape so we didn't . they are pretty cheap to get though if you decide to. I installed the catted version you are catless that will give you more wiggle room for placement, that was the hardest part to do. my shop guy also has a lift that would definitely make it easier. I would not even consider doing without a lift.
      08-02-2016, 08:53 AM   #3
SakM_5
scale=2.5
According to what I've seen, a lift is not needed at all since the only thing you are doing from the bottom is removing the 4 nuts attaching to the midpipes and the rest of the job is from up top.
      08-02-2016, 08:58 AM   #4
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
heres a diagram if it helps also.
      08-02-2016, 09:08 AM   #5
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
You can do it without the lift. It just makes it so much easier to be able and stand up I'm sure, It also has other benefits to lift to inspect the underside of vehicle and be amazed at the quality and craftsmanship it took to build and take a few snapshots under there.
      08-02-2016, 09:10 AM   #6
SakM_5
I wish I had access to a lift but I don't so I'm going to have to bite the bullet without a lift. As long as I can get the car high enough to crawl under and get those 4 nuts off I'm assuming I should be good?
      08-02-2016, 09:18 AM   #7
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Here is a write up done by RPI. Its all the same.
http://www.m5board.com/vbulletin/rpi...on-f10-m5.html
      08-02-2016, 09:20 AM   #8
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
we also took one of underpanels off to make it easier to get to the bolts on the exhaust/downpipe coupling.
      08-02-2016, 09:23 AM   #9
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
Thats the same one that I used.
      08-02-2016, 09:28 AM   #10
SakM_5
Yea, I saw the RPI write up. I just wanted to hear from guys on here that had first hand experience.
      08-02-2016, 10:40 AM   #11
13M5F10
13M5F10's Avatar
it takes about 3 hours but if it's your first time and you don't have access to a lift it can take longer. as some have said, you don't need a lift but you will need to get underneath the car somehow. obviously it's easier with a lift.
as for the gaskets. I would replace them. they are crush gaskets and only good for single use.
      08-02-2016, 11:13 AM   #12
SakM_5
Which gaskets? according to the diagram it only shows gaskets between the downpipe and midpipe, nothing between turbo and downpipe?
      08-02-2016, 11:15 AM   #13
13M5F10
13M5F10's Avatar
Correct, that's the only one I am aware of.
      08-02-2016, 11:23 AM   #14
boots
Curve Thrasher
boots's Avatar
623
And make sure you torq the bolts afterwards
      08-02-2016, 07:08 PM   #15
TrevorM3
Drives: 6.3 AMG
part # for crush gaskets?
      08-02-2016, 07:41 PM   #16
M6Pilot
M6Pilot's Avatar
32
Drives: 2015 M6 GC
Spacer flange 18307844741 $6.63
Gasket ring 18307843213 $16.34
      08-02-2016, 08:56 PM   #17
TrevorM3
Drives: 6.3 AMG
ok just one of each?
i'am putting a brand new set of cats on a car with 40k, and taking the catless dps' off the car with 40k and putting on a brand new one.
swapping.
      08-02-2016, 11:26 PM   #18
SakM_5
decided to tackle the job tonight and it took me longer then expected. i suggest to anyone who is going to do this to make sure they get an o2 socket first and a magnet would help so you don't loose screws as many are in tight places. I ended up using my old gaskets because the car only has 11k miles and they looked brand new. I lost one of the nuts holding the mid pipe to the flange, so I have to get one and do that tomorrow. Took it for a ride and the car sounds 100% different.
      05-23-2019, 11:40 AM   #19
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
2007 BMW 335i  [0.00]
Can someone explain how the gasket ring goes onto the midpipe?
I see you explained that in 12a but I thought there was only 1 gasket, now I'm realizing theres two and I did not mess with it... I ended up having fitment issues with the driver side but just blamed it on the downpipe. Could this have been because of the gasket being in the wrong spot?
This is the gasket i'm talking about:
https://www.ecstuning.com/b-genuine-...h/18307843213/
      05-23-2019, 11:48 AM   #20
Dwaynos
Dwaynos's Avatar
The flat gasket slide onto the downpipe first then the sealing ring slides on afterwards. These must be fitted to the downpipe not the midpipe otherwise you will have trouble getting them together.
      05-23-2019, 08:05 PM   #21
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
I used an exhaust jack to push the midpipe back into the downpipe... oops. Might have really f***d that sealing ring. I ordered some new ones.
