      05-24-2019, 02:23 PM   #1
mikey_g
Drives: 14 M5 6SPD
Engine modification: required accessories and preventive actions for exploding engine
Aloha all,
Just bought stage 2 pure turbos and vsfr downpipes along with RPi GTM exhaust . This should all get me some more competitive numbers at the wheels, going for some drag radials (hopefully 305) to help put it down. I do realize through a bit of browsing that as awesome as the HOT V Twin turbo s63tu is, that shit might blow up. I've got a 3rd party warranty but I'd really like to avoid the whole mess and I was wondering if you all could recommend some accessories (I've been told meth is not req?) to help in the prevention or at least reduce the risks of an engine going boom.
Mahaloz from Hawaii,
Mike
      05-27-2019, 04:22 AM   #2
OneExtra
OneExtra's Avatar
Drives: None
New clutches will be your next modification, would your warranty not be invalid with all of the mods?
      05-27-2019, 01:33 PM   #3
induc916
Drives: 2014 M6
A good tune, gapped plugs and coils.
      05-27-2019, 06:07 PM   #4
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
2007 BMW 335i  [0.00]
Originally Posted by mikey_g View Post
Aloha all,
Mike
Change your plugs, coils. Change your oil ever 3500 miles. You will HAVE to run at least 305 or better 315 if you want to get your moneys worth on the power, which also means new clutches.
and the list just keeps getting bigger... always does.
If you're running stage 2 turbos, you will want to run a meth set up. Not for power but for cooling. (you will get some power, even though it's not the goal maybe +30). You could even run distilled water to keep IAT down..
I'm not pure stage 2 but considering it, in the process I've spoke to some guys running 800+ hp set ups and most run meth for the purpose of keeping their temps down. Will also help with heat soak. You can expect temperatures of 100 degrees cooler with meth than without.
      05-31-2019, 01:17 AM   #5
mikey_g
Drives: 14 M5 6SPD
Yeah I've read the same in regards of meth and temp.
305s will run on the rear 343m https://f10.m5post.com/forums/showthread.php?t=1390088 but im on the lookout for wheels that can fit a 315 tire!
TBH the stage 2 turbos might be the last thing installed even though it was the first
Also clutch will be bought, the 6 speed can only handle roughly 650 tq I've been told
_BSMM5123.50
      05-31-2019, 01:18 AM   #6
mikey_g
Drives: 14 M5 6SPD
Believe its covered
      05-31-2019, 11:23 AM   #7
_BSMM5
_BSMM5's Avatar
Drives: 2015 M3
DCT can handle up to 650 TQ. The manual has a bit more tolerance, I'm not sure of the exact number but I think its at least 700 Tq. Have fun with that
