01-22-2020, 03:36 AM | #1 |
Rep 76
Ram air filters m5 f10 good or bad
Hi guys
Thinking of fitting these after post from finance Nick good or bad ? Foam so shouldn't let oil In Also told can cover maf sensor in oil so not to ? |
01-22-2020, 03:51 AM | #2 |
Rep 1,406
You're thinking too much about it. Just do it. Many have done it with good results. If you're worried about the filters in general get a dry cotton media filter and fit it over where you cut the oem filters.
01-22-2020, 04:14 AM | #3 | |
Rep 76
Video that they spend lot of time cleaning customers. Mag sensors for cars with the filters |
LSM349.50 |
01-22-2020, 06:19 AM | #5 |
Rep 76
01-22-2020, 07:36 AM | #6 | |
Rep 169
I meant, has anyone run the Proram filters from Ramair?
BMW F10 M5 Competition
Hyundai i30N Porsche 986 Boxster S |
01-22-2020, 07:39 AM | #7 | ||
Rep 76
I've not seen the pro model what's the different from that to the normal universal ram air filter in foam have you a link to that ? Thinking of getting tommy to map my m5 but I'm 4 hour s ish away so maybe just do bm 3 |
01-22-2020, 07:44 AM | #8 | |||
Rep 76
https://www.ramair-filters.co.uk/pro...ram-universal/ Not sure what material these are they look similar to k & n which no are ones that can be oil based ones |
01-22-2020, 07:57 AM | #9 | ||||
Rep 76
01-22-2020, 12:25 PM | #10 |
Rep 948
Unless you want to spend a lot of money you have no choice but to get oiled filters. There is a dry alternative made by eventuri but they are drop in panel filters.
01-22-2020, 03:19 PM | #11 |
Rep 76
01-23-2020, 06:34 AM | #12 |
Rep 606
Besides oiled filters eventually fouling the MAF sensors, the other drawback could be increased engine wear. Especially if you don't service the filters regularly. Basically just a little higher risk since the filter elements are exposed to everything - rain and even more "debris" than the stock intake location. Most people don't mind the risk since it's not that high, but for long term use it's something to be aware of. I only bring it up since you're asking pros/cons.
01-23-2020, 11:43 PM | #13 | |
Rep 76
Grill to them or try an connect to the stock air duct some how? |
