05-26-2018, 09:28 AM | #1 |
Rep 99
Rubbing in rear
My car is completely gone stock. I am running the stock tire sizes with brand new Michelin Pilot 4S. The car has no noise until 20-25mph and then there is a rotational metal noise coming from the passenger rear tire area. The noise will continue all the way through no matter the speed until the car is traveling under 20MPH. My rear brakes are almost due, they have 5mm left on the pads. I've checked the brake shields for rocks and there was nothing. What could it be? It's very loud
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
05-29-2018, 03:39 AM | #2 |
I'm The Captain Now
509
Rep 1,818
Drives: X5M/X7
Garage List 2021 BMW X7 MSport ... [0.00]
2018 Raptor [0.00] 2015 X5M (SOLD) [0.00] 2014 BMW M5 (SOLD) [10.00] 2014 BMW M5 Totaled [10.00] 2014 Jeep SRT (SOLD) [0.00] 2012 C63 AMG (SOLD) [0.00] 2015 BMW M4 (SOLD) [0.00] 2011 Porsche Cayenn ... [0.00] 2007 911 Turbo (997 ... [0.00] 2013 335i M Sport ( ... [0.00] 2002 Porsche 911 Tu ... [0.00] 2008 BMW 135i (SOLD) [6.00] 2002 BMW M3 SOLD [10.00] |
I had this happen to me on another car of mine.
It turned out to be a heat shield that was rubbing on the driveshaft. Like your case, mine was only above a certain speed and this was due to the force of air pushing it back until it made contact with the driveshaft. Might be something to inspect. I found it by inspecting all rotating parts (axles/driveshaft) under the car until I found the fresh marks on the driveshaft where it was rubbing. Just something to check.
05-29-2018, 01:50 PM | #3 | |
Rep 99
05-30-2018, 09:48 AM | #4 |
Rep 99
The noise is very loud, I cant re create the sound with the car jacked up. I checked the heat shields and nothing is bent. It's definitely not the brake shield, the first thing I did was push that all back and the noise was still present. No rocks in caliper/pad.
The noise starts around 20mph and stays pretty consistent all the way up the mph getting just slightly louder. I'm thinking it's a bad rear wheel bearing but how common is that? I know we have to replace the whole hub assembly so I was trying to avoid that but I think that may be the problem. I cannot emphasize the level of volume the rubbing produces. It is a purely rotational rubbing noise, not really a metal scraping noise just a super loud rub. |
12-08-2018, 01:07 PM | #5 |
Rep 41
Did you ever find a solution to this? My f10 is doing the same thing, I cannot find where the sound is coming from and it's driving me crazy. Seems to happen more on deceleration.
12-08-2018, 01:09 PM | #6 | |
Rep 41
12-08-2018, 06:32 PM | #7 |
Rep 21,531
I read on forum a while ago that someone else was having rubbing issue due to loose rear stabiliser bar.Would have to get it on ramp with full weight still on wheels probably to check.
Patrick86ed7.50 |
12-14-2018, 09:32 AM | #8 |
Rep 99
It was the passenger side wheel hub. Once I replaced it the noise was completely gone. Check into the hubs, they fail frequently.
Shift the weight of the car by slightly swerving at safe speeds. If the noise disappears then it’s a hub. |
