02-16-2019, 03:40 PM | #1 |
Rep 978
Turbo care
Up to this point in time, from my participation on this forum, I have read only small tidbits as to "how to care for your turbo" with regards to lubrication. What I am talking about is when an M5 owner is out for a day or night or hard running with you car, do you let the motor run at a low rpm for a minimum of time to prevent coking of the oil left in a very hot turbo.
I know that some big rigs have a turbo timer which can be set by the driver to achieve a complete and proper cool down of the oil going thru the oil system and turbo. It is a problem with big rigs after running up and down mountains and passes where the turbo takes a beating. Any thoughts?
2021 M340i
02-16-2019, 06:09 PM | #2 | |
Rep 19,524
02-17-2019, 07:01 PM | #3 |
Rep 608
That's why it's so important to have a full charge battery. No need to leave car running if your battery is full charge. Just a little info on these cars is that the battery charges on deceleration and when the ecu sees that the battery is 80% it's considered full charge. So what I do is trickle charge my battery every few months. The ecu measures the battery when the motor is off and will turn off the aux waterpump before it's finished cooling the turbos if it's low, causing the oil to cook in the lines eventually causing a blockage which in the end will cost you a turbo. So battery maintenance is super important for turbo maintenance. And by the way bmw recommends changing the battery every oil change lol.
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
02-18-2019, 08:52 AM | #4 | |
Rep 978
2021 M340i
02-19-2019, 11:54 AM | #5 | |
Rep 606
02-20-2019, 07:36 AM | #7 | ||
Rep 608
technician117251.00 |
02-21-2019, 12:18 PM | #8 |
Rep 606
02-21-2019, 05:25 PM | #9 |
Rep 608
The IBS measures the state of the battery. When it gets to low it'll start to shut off non essential electronics. So yes if your battery is low then it'll affect the cooling process. Bmw has a ecu update to address the sensitivity of the IBS.
