      09-10-2018, 09:14 PM   #1
WickedBMW
WickedBMW's Avatar
Drives: 2021 BMW M3 MT
Snow Performance Meth Kit Recommendation
I looking to purchase snow performance meth kit. I’m looking at the stage 3, but I’m not sure how many nozzles and what size is required, and how much piping is needed. I already have chargepipes, btw. Does anyone here has this set up? Please advise. Thanks
?When you have fast cars and bad luck, it's a lot easier to handle than having slow cars and bad luck.?
Kevin Harvick
      09-11-2018, 06:41 AM   #2
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I'm running it. I'm using two nozzles #4. I'm also using the nylon hose. If you plan on going with the steel braided hose make sure they send you the right fittings. The only thing I added was an adapter on the charge pipe to get a boost reading. Pm me if you have anymore questions. This is the kit I'm using
https://www.snowperformance.net/Stag...-p/sno-320.htm
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
WickedBMW612.50
      09-11-2018, 08:30 AM   #3
WickedBMW
WickedBMW's Avatar
Sent you PM
Kevin Harvick
      09-12-2018, 10:40 AM   #4
ltym5
Drives: M5
I'm also interested in adding a meth kit to my car. Can you show me a picture of your installation? Also, do I need to get charge pipe for stage 3?
      09-12-2018, 04:04 PM   #5
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
How hard is this to install at home
      09-12-2018, 06:34 PM   #6
WickedBMW
WickedBMW's Avatar
I was told it would take four hours to install it.
Kevin Harvick
      09-12-2018, 08:06 PM   #7
schnell1982
Drives: FAST
It all depends on how well routed and protected you want your lines.
If you are running real methanol, I would advise to have the lines protected and not rubbing on anything that could puncture a line.
Aside from that and the electrical work, mounting the tank / pump ... 4 hours is not enough.
Unless you're just gonna throw it in there
WickedBMW612.50
