07-03-2018, 05:21 PM | #1 |
Rep 1,107
Dash Cams
Hey guys, Im looking to buy some dash cams, for my daily, wifes car and the M5. If you guys have any or some reviews of a good camera, please share!
Thanks!! |
07-03-2018, 05:54 PM | #2 |
Rep 232
I’m happy with my Vantrue N2. I bought for two of my cars, and I like that it can easily be transferred to another car if needed. I strongly believe a dash cam is quickly becoming a must have item to cover yourself in an accident.
07-03-2018, 05:56 PM | #3 |
Rep 1,107
Thanks, absolutely agree. Now did you run the wire to a switched source or plug it in everytime? Im looking for a hard wire option so it comes on and turns off with the key. Thanks
07-03-2018, 05:59 PM | #4 |
Rep 881
most of the decent dashcams are good and robust. Avoid one that mounts directly to your windshield; rearview mirror mounted cams, you can cover with the sunscreen at least.
Its the memory cards that you have to worry about if exposed to too much heat over time; just check your recorded videos every once in a while to see when the microsd cards crap out. We have dash cams in every one of our cars. Edit: we use the kdlinks r100 dashcams
2014 "AW/SO"me M5
07-03-2018, 06:01 PM | #5 | |
Rep 1,107
07-03-2018, 10:07 PM | #6 |
Rep 608
I'm thinking of this one
https://dod-tech.ca/product/dod-rc500s/
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
07-04-2018, 12:19 PM | #7 |
Rep 279
Drives: 2021 M5 Comp, 2011 M3 E93
I have the BlackVue DR750S-2CH with power magic pro (for battery control while car is off) and it works great!
07-04-2018, 03:37 PM | #10 |
Rep 269
I live and die by my Waylens Horizon. Hardwired to a fuse in the glove box.
https://www.waylens.com/horizon
2021 Brands Hatch Grey M5 Competition
07-04-2018, 09:47 PM | #11 | |
Rep 80
07-05-2018, 02:31 AM | #13 |
Rep 473
I have a BlackVue DR500GW, which is a pretty old model now, but it has worked flawlessly for more than 3 years now. My camera is hardwired to a fuse in the glovebox and is situated just underneath the KAFAS camera. It turns off automatically after you shut off the car and enters parking mode (only comes online when it detects motion). I haven't gotten any warnings for battery drainage for the years I've been using it. It only records 1080p, but as others have mentioned, there are newer models out there.
The wifi transfer of videos is rather slow, which is annoying. I'm guessing it hasn't gotten any better with newer models, but others can chime in on that. Back when I was researching dash cams BlackVue were one of the top choices.
07-05-2018, 10:04 AM | #14 |
Rep 881
https://www.amazon.com/GIKERSY-stand...g+usb+c+reader
I keep one of these otg USB readers in each car so I can quickly pull the micro SD card and check/transfer the videos on my android phone. |
05-12-2021, 06:56 AM | #16 |
Rep 284
Was looking for some dash camera info and ran across this old thread. After lots of searching and research I ended up with the Viofo A139. Here is my review on amazon. I have had it for a month or two and am very pleased with it.
L |
