07-13-2018, 07:58 PM | #1 |
2291
Rep 1,915
Drives: Many, BMW.
FS: 5AD Lane Departure Warning Retrofit - Radar Sensors / Switch / Wiring
LDW (Lane Departure Warning) aka Option 5AD This kit consists of the essentials for the foundation, which will only require the addition of LDW equipped mirrors (Original non-LDW mirrors can be upgraded / or you can purchase complete replacements) Wiring is pretty straight forward. All the wiring is pin to pin, so no cutting or splicing necessary, you will simply pop the pins into their designated place, install the sensors, swap out the switch, and code the option in. I'll provide the pin location, and routes for wire guidance that will make this a fairly easy retrofit. The 2nd part of the LDW/5AD is the vibrating steering, which solely becomes an option, and is not necessary for the feature to work. Post sale support and help with any questions you may have with retrofitting on this platform is available. Can also sell wiring and harnesses individually - PM or text (732-677-9030) with your needs. |
