12-05-2014, 02:17 PM | #1 |
Rep 395
B&O Much more quiet for Pandora
For some reason whenever I use Pandora on my phone connected by the USB port, the system requires that I put the volume much higher to get the same amount of sound compared to raising it maybe half way for Sirius. It must be the system because on a loaner 535, the regular audio that I plugged my phone in to use Pandora was much much louder. Does anyone know why that might be? Is it something in the settings I can change?
This occurred both in my older 13 M5 and now in my 14. Again this is for the B&O system. Thanks! |
12-05-2014, 04:07 PM | #2 |
Rep 1,425
I don't use Pandora, nor how your interface from your phone to USB interacts. However, in similar setups of other vehicles of mine, I have to turn the volume up on my phone once an app like Pandora is playing. Not sure if that's an option with your setup.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
12-06-2014, 10:22 AM | #4 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
I've noticed this as well via Bluetooth connection.
Unlike my 2013 m3, the volume on the iPhone is adjustable when in Bluetooth mode in my M5. As mentioned above, you might want to check your volume slider. Even full blast, mine is still a tad quieter than the radio though. It's not much, but I notice it.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
12-06-2014, 03:24 PM | #5 |
Rep 395
Phone volume has no effect. It doesn't work in the same manner as lets say just using an audio jack. BTW i would highly recommend using an internet radio app because the quality is exponentially better than satellite radio and HD radio, for any system mind you.
12-06-2014, 03:25 PM | #6 |
Rep 395
Yeah it does not work like an audio jack input type setup. The bluetooth and the usb connection alike work in the same fashion. It's simply something with the B&O because the regular sound system in the 5 series did not have this issue when I had a loaner.
12-06-2014, 03:28 PM | #7 | |
Rep 395
12-06-2014, 03:37 PM | #8 | |
Rep 1,917
Matt
12-06-2014, 03:47 PM | #9 | |
Rep 395
Trying to figure out why Pandora is not anywhere near as loud on the B&O system. I connect my phone via USB or Bluetooth. Either way does not matter, and the volume is rather weak and needs to be turned up twice as much compared to say the satellite radio volume to have the same level of sound. Also that read the thread pic is rather distasteful and i don't look or feel that way, it was just convenient lol. |
12-06-2014, 05:49 PM | #10 |
Rep 1,425
I do - Google Play All Access. It streams at 320Kbps. Pandora peaks at 192 Kbps, last I checked.
2017 X5M - Current
12-06-2014, 07:16 PM | #11 |
Rep 395
12-07-2014, 02:20 PM | #13 |
Rep 395
03-28-2015, 09:23 PM | #14 |
Rep 4
BMW M5 2015 with Bang & Olufsen...
Is possible install a subwoofer (10") in the car trunk? If possible, as is control of subwoofer? Is independent of original system? |
03-30-2015, 07:09 PM | #15 |
Rep 395
I'm not sure, that's something that I would post in the forum as it's own topic. I'm sure someone will have experience with that kind of modification.
