      07-02-2019, 02:41 PM   #1
Oompah
Drives: M5
Cracked headlight lens
Hi all,
Just realised one of my headlights has a relatively long crack on it.
Anyone has experience with repairs of such damage? Or is it a full headlight replacement scenario?
Thanks
      07-02-2019, 05:29 PM   #2
OneExtra
OneExtra's Avatar
Drives: None
That won't be cheap to replace, maybe look on EBay for a used one and then swap over the modules
I have just bought some pre-cut PPF to cover the headlights to stop this happening and stone chips
      07-03-2019, 10:06 AM   #3
Oompah
Drives: M5
£2100 + fitting.
OneExtra810.50
      07-03-2019, 12:28 PM   #4
Possible to just replace the glass?
      07-03-2019, 12:49 PM   #5
OneExtra
OneExtra's Avatar
Drives: None
No it's a sealed unit and it's plastic not glass
      07-03-2019, 01:06 PM   #6
Your right it's polycarbonate, have just watched a u tube vid of how to replace a pre lci headlamp lens on one unit. LCI would be similar,it's a bit of work requiring some skill and a shed load of money can be saved if you do it right.
      07-03-2019, 01:20 PM   #7
HeadlightHeartSurgeon.
      07-04-2019, 05:58 AM   #8
schrickm5
schrickm5's Avatar
Drives: 2013 M550d xdrive touring
I did my E39 lights - they needed to go in the oven for about 30minutes....is it still glue that holds the Lens to the unit? If it is, then it might be an oven job....
2015 M5 CP Blue
[SIGPIC]
Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 >
      07-04-2019, 06:18 AM   #9
Definitely oven then the HHS was using black silicone sealer I think with the new lens and securing with clips until set. Like another poster did I have ordered a roll of lens protector film to prevent this happening to mine.
      07-04-2019, 09:12 AM   #10
OneExtra
OneExtra's Avatar
Drives: None
You don't need a roll you can buy pre cut pieces
      07-04-2019, 09:20 AM   #11
OneExtra
OneExtra's Avatar
Drives: None
Both of my headlights have this on them and it's supposed to be there, is this the same as yours
      07-04-2019, 09:22 AM   #12
OneExtra
OneExtra's Avatar
Drives: None
Other side
M5Rick60013.50
      07-04-2019, 12:27 PM   #13
Other side
It's a roll I ordered like 3' by 1' but probably not as thick as yours, nothing expensive from Far East,probably have to wait for ever as for my exhaust tips.
Where did you get your pre cut ones from.
      07-04-2019, 02:01 PM   #14
OneExtra
OneExtra's Avatar
Drives: None
Other side
https://www.aliath.co.uk/collections/bmw
      07-04-2019, 02:39 PM   #15
You've convinced me and I've ordered a pair,I'll use the other roll for something else.
      07-04-2019, 03:06 PM   #16
Oompah
Drives: M5
An interesting twist in my scenario. Bmw diagnosed and quoted but I also decided to visit friendly windscreen repair man who, I thoughts, could perhaps try to fix it.
Instead he promptly removed some hardened, silicon/plastic like string of material from the headlight lens with a polishing pad...
I guess something landed on my headlight and hardened in high temperature, leaving crack line looking, heart attack giving line.
Bottom line, I saved almost £2500... phew.
(yes, I felt like a right plonker in front of the windscreen repair guy)
Btw. regarding protection film on headlights, when i had my car ceramic coated, I was told the film makes sense only on very new headlights. Existing micro stone chips on the headlight covered with a protection film, apparently look pretty bad.
OneExtra810.50
      07-04-2019, 03:11 PM   #17
OneExtra
OneExtra's Avatar
Drives: None
Glad it's all sorted and thanks for the heads up on the film
      07-05-2019, 07:40 AM   #18
schrickm5
schrickm5's Avatar
I just ordered the film from the UK, as the Swedish prices are almost double.
I have a new headlamp on one side, and the other is good....so something to do next week!
Thanks for the link!
2015 M5 CP Blue
[SIGPIC]
OneExtra810.50
      07-08-2019, 05:39 AM   #19
Good morning.
Just received the kit but before I apply it the instructions state that smaller pieces of film can be applied dry e.g. on arch protectors.Did you fit your headlight protectors dry?
      07-08-2019, 05:54 AM   #20
OneExtra
OneExtra's Avatar
Drives: None
Good morning.
Not fitted yet but I wouldn't fit dry 100% mix a solution and the below
      07-08-2019, 06:06 AM   #21
I think I'll wait a bit too until I finish the garden, plenty to do there!
      07-08-2019, 06:47 AM   #22
OneExtra
OneExtra's Avatar
Drives: None
Make sure the lens is as clean as possible and then maybe wipe it with IPA the remove and oils, waxes etc
