02-12-2020, 12:45 PM | #1 |
Rep 248
Mmp gtx3076r dual ceramic ball bearing s63tu bmw m5 m6 x5m x6m
These are GTX3076R dual ceramic ball bearing with billet center section twin turbos that move 55lbs of air each capable of making 1000whp+ on E85 or meth. USED SET WITH maybe 600 miles on them. Going a different turbo setup. Turbo Specs: Dual ceramic ball bearing S63TU bolt on twin turbos for the M5, M6, X5M and X6M v8 twin turbo BMWs. Billet aluminum compressor wheel for high flow They have 7075-T6 high strength aircraft grade billet aluminum CNC machined center sections hard anodized gold saving 2lbs per turbo (4lbs total) and much stronger than the stock castings and ALOT better at heat conduction to keep the turbos cool. The bearing housings have a super expanded 5x larger internal water jacket for extreme high performance cooling. They have a dual ceramic ball bearing cartridge which provides best possible spool and durability. Bolts onto stock Downpipes, chargepipes, oil, and coolant lines with no fuss, perfect fitment, easier than installing OEM turbos. Each turbo can flow 55lbs/min of air max. Because the dual ceramic ball bearing and super strong and super cooling billet bearing housing is super reliable. Car model fitment (confirmed fits perfectly): 2011–2017 F10 M5 2012–2018 F12/13 M6 2013–2018 F06 M6 Gran Coupe 2018–present F90 M5 2018–present F90 M5 Competition
02-14-2020, 02:09 PM | #2 |
Rep 248
MMP - "Yes no problem I will transfer the warranty"
02-21-2020, 09:11 AM | #3 |
Rep 248
New Price Bump
03-01-2020, 08:55 PM | #4 |
Rep 248
Bump
03-07-2020, 05:43 PM | #5 |
Rep 248
Bump
