      02-11-2017, 11:47 AM   #1
Icyjaws
Drives: 2008 335i
Portable car lifts
Looks like I'm finally getting a garage and tired of doing all the work on my cars (92 mr2-t and 2008 335i) on jack stands. any one have experience with either quickjack https://www.quickjack.com/car-lift-s...-car-lift.html
or EZ car lift http://www.ezcarlift.com/
the quick jack is like $500 cheaper but only 20" vs 26" 26" for the EZ. It be nice when putting the motor back in my mr2 again to have even a 20" lift.
      02-11-2017, 12:10 PM   #2
08njSTEP
08njSTEP's Avatar
795
Drives: '07 335i, '66 SS396 Chevelle
I think the biggest issue is ceiling height. My dad wanted to get a lift to double his parking spaces. He had 5 Corvettes and a 2 car garage. Ultimately his ceiling was too low to allow 2 stacked cars. I would call the manufacturer and see what their recommended minimum height is.
      02-11-2017, 12:28 PM   #3
GATORB8
GATORB8's Avatar
Drives: 2011 335is 6MT
2011 BMW 335is  [9.50]
Between the two, the Quickjack looks like the superior product to me. ezcarlift is more expensive and doesn't even include the "drill" you use to operate it, although I guess that makes it a little more portable.
      02-11-2017, 12:48 PM   #4
lakefront
Drives: 2017 Macan GTS
About a year ago, bought a portable 2 post lift called a MaxJax by Danmar. Supposed to be a BendPak design built in China. Individual posts that bolt to the concrete floor, 6000 lb capacity. Was a little skeptical, but so far has been just a fantastic tool. A little pricier at around $2000, but its a real hydraulic lift. Made for lower ceilings, it only raises about 4 ft, but can easily work on roller stools underneath.
      02-11-2017, 03:19 PM   #5
GATORB8
GATORB8's Avatar
That's actually the same price as the EZ car lift.
Edit:
Danmar also has a lift similiar to the two posted by the OP, but better lift height:
http://www.dannmar.com/dannmar-produ...fts/SX-6XL.asp
      02-11-2017, 09:36 PM   #6
Nkc
NOOB
Nkc's Avatar
Drives: Cars
I have the quickjack due to a low ceiling height. It's great for what it is but you're really limited to what you can do under the car.
If I had the height to stack two cars, I'd get maxjax.
      02-11-2017, 09:46 PM   #7
Haywood
I know a thing or 2 about a thing or 2...
Haywood's Avatar
3101
Drives: E36 M3 Coupe, e39 M5, i3s
2003 BMW e39 M5  [0.00]
1997 BMW e36 M3  [0.00]
After looking at the other products, I think I'm going with this one:
http://www.gregsmithequipment.com/At...e-Scissor-Lift
I like the fact that it's portable and don't have to bolt it down. You can even move it to another part of your driveway and/or street if needed.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1
1997 Alpine White e36 M3 (the old gal)
2013 Mineral White e92 M3 (sold )
2014 Carbon Black 650i M-sport (sold)
      02-12-2017, 07:44 AM   #8
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Of the two in the first post, I'd go with the Quick Jack. But, how is that realistically any different in workable space than a good set of jack stands? I get it is faster to put up, but it only takes me ~10 mins to put a car up on jack stands.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      02-12-2017, 07:50 AM   #9
Haywood
Haywood's Avatar
3101
I totally agree. That's a lot of money for not much height. That's why I feel a scissor jack is a better alternative if you can't get a 2 post or 4 post lift in your garage.
      02-12-2017, 08:04 AM   #10
Twt
Twt's Avatar
634
Drives: 2017 M2
I bought some hydraulic skates from Greg Smith several years ago and the quality was superior to the other ones I looked at....plus great customer service .
Haywood3100.50
      02-12-2017, 08:14 AM   #11
Haywood
Haywood's Avatar
3101
Thanks. Good to know.
      02-12-2017, 09:54 AM   #12
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I've had that lift for many years now and it has lasted very well.
Don't get too excited about portability though, it's pretty heavy duty.
Also, you will need ramps of some sort so that you can drive over it.
The floor also needs to be reasonably level.
I now have built in ramps, which have worked out great.
I also cut steel plates into the floor for the rollers to run on.
Over time it wears down the concrete.
http://www.zpost.com/forums/showthread.php?t=1219652
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      02-12-2017, 10:27 AM   #13
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
I have the ex car lift. Works great but slow and can't use on my x5d due to it being fat pig. Would have gotten something else but only paid 500 so went for it
      02-13-2017, 03:50 PM   #14
Icyjaws
Drives: 2008 335i
how are the scissor style jacks as far as working on say the transmission or exhaust mid-pipes? I would think that could be a real draw back to that style lift. as some of said I may just save the cash and buy a nice jack and call it a day but putting the motor in my 2 was a pita last time I did it with jacks, jack stands and a hoist cause its easiest done by lowering the car onto the engine. also like to be able to do "normal" maintenance easier on the e90
      02-13-2017, 04:45 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Icyjaws View Post
how are the scissor style jacks as far as working on say the transmission or exhaust mid-pipes? ............
Better than you would think.
You get used to working in the center.
It works pretty well for exhaust because the cross frames help to support it.
      02-13-2017, 04:51 PM   #16
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
+1 that's a awesome garage you have there! Well done.
inTgr8r2431.50
      02-19-2017, 11:25 AM   #17
flyinb501
Drives: 2009 E90 335i
+2, very nice! What are the max lift point dimensions? I've heard some people have issues reaching lift points on larger cars with these.
Also, has anyone considered the harbor freight unit? It can be had pretty cheap with coupons.
http://www.harborfreight.com/6000-lb...ift-91315.html
I really want to buy one of these, I'm just concerned it won't work for me once I upgrade my 3 series to a bigger family car. Any input is appreciated!
inTgr8r2431.50
      02-19-2017, 04:39 PM   #18
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Correct, the awing arms can be a limiting factor.
However, there are different length arms available when ordering.
