02-27-2019, 06:42 PM | #1 |
Rep 461
Issue with BMS Tune after install
Installed stage 1 tune (from a forum member) on Sunday and ran into a CEL. Carly says it's "102A01. Fault Explanation: Air mass meter, signal: electrical fault."
Oddly, it didn't throw the code right away, only after restarting after initial drive. I cleared the code (and like 100+ others) at lunch today but when I started car for drive home, CEL was back and the code (and 38 others) had returned. Any ideas? |
02-27-2019, 06:50 PM | #2 |
Rep 1,254
Sorry, I'm not much help but I do know that the MAF's in these cars do go bad pretty regularly.
02-27-2019, 09:51 PM | #6 |
Rep 461
Nope that's not it. Car running well, the tune is working. Tonight I noticed a new code. Same issue, other side.
02-27-2019, 09:52 PM | #7 |
Rep 123
02-28-2019, 11:58 AM | #8 |
Rep 606
"I cleared the code (and like 100+ others)"
"CEL was back and the code (and 38 others) had returned." You shouldn't be getting tons of codes just randomly. Sounds like a DME connection isn't seated right. Did you do any work in that area recently? |
02-28-2019, 12:05 PM | #9 |
Rep 461
Sunday was my first time even checking the codes as I purchased the car last fall and did not have a code reader. I assume they were from the original owner's tenure. When I ran codes again this AM, I am only getting the two that I mentioned.
02-28-2019, 12:07 PM | #10 | |
Rep 461
Also, car is running great, no power loss or limp mode. Just the codes and CEL. Thank you! |
02-28-2019, 12:25 PM | #11 |
Rep 553
You need new MAF. Idk why but this car the MAF is made from garbage. It can go bad just by looking at them wrong lol.
I'd replace both. They were gonna go soon anyway if that's any consolation. |
02-28-2019, 12:27 PM | #12 |
Rep 461
Thanks for this advice. Assuming you mean MAF sensors, right? Any suggestions on where to purchase and which ones have proven to be the most reliable?
03-01-2019, 06:06 AM | #15 |
Rep 461
03-26-2019, 11:39 AM | #16 |
M Enthusiast
36
Rep 171
I'm having a similar issue. I have both the BMS stage 1 tune as well as the BMS intakes. For me though, the air intakes are causing a CEL to stay on and i'm getting the same error code about the air mass flow sensor (too much air flow). If i put the stock air intake back, the CEL goes away. Do i need to clean the MAF sensor or replace them? Anyone else having the same setup issue?
03-26-2019, 12:58 PM | #17 | |
Rep 123
BMS intakes are known for throwing CEL, Contact Mike he might be able to help. I wen't with Project_Gamma Grill intakes and never seen CEL in my life. |
03-27-2019, 09:25 AM | #18 |
M Enthusiast
36
Rep 171
Thanks! I contacted Mike and he advised me to clean the MAF and re-install them. I did that with MAF cleaner then drove the car for about 20 miles but the CEL is still on. Does anyone else have any recommendations?
08-02-2019, 02:16 PM | #19 |
Rep 1
Aayaz did you resolve this problem? I just installed jb4 no boost and bms intakes on 2013 m5 and am getting same cel light and am having to clear everytime I restart engine.
Any help towards resolution would be great! |
08-02-2019, 02:50 PM | #20 | |
Rep 226
94jedi829.00 |
08-02-2019, 02:57 PM | #21 |
M Enthusiast
36
Rep 171
I still am having the same issue! CEL is still on but no problems driving the car. I too am kind of stuck in the same situation. If i clear the code, obviously CEL goes away but comes back on a couple days later. Sometimes the code will dissapear on its own then come back so every time the car restarts the ECU is checking all components and sometimes it catches something and sometimes it doesn't. Wish i could be of more help.
08-02-2019, 02:58 PM | #22 |
M Enthusiast
36
Rep 171
