      06-16-2019, 12:26 PM   #1
lotus49
England
9
Additional oil change?
I recently bought a 2014 F10 M5 with 37k miles on the clock. It looks to have been well-maintained (everything is in good condition) and serviced at main dealers in accordance with the service schedule.
The next oil change isn't due for another 7000 miles (or until 4/2020), which seems like quite a long time. I am slightly paranoid about the engine blowing (I know it's not likely but it happens and it's a very expensive problem to have) and wondered whether it's worth doing an additional oil change. I assume but don't know that the correct oil was put in it at the last oil change.
What do people think?
      06-16-2019, 12:43 PM   #2
Ickdeep
Ickdeep's Avatar
2013 BMW M5  [5.00]
2015 BMW X5  [5.00]
2013 BMW 535i [SOLD]  [5.00]
I personally change my oil every 4-5k miles.
As for what oil you use, it kind of depends. I would recommend calling your dealer and see what they recommend for your car.
      06-16-2019, 01:59 PM   #3
Boosted M5
Drives: F10 m5
I second that!
      06-17-2019, 11:56 AM   #4
AirBull
AirBull's Avatar
Drives: 2015 BMW M5
2015 BMW M5  [0.00]
Time is a factor as well as the miles; change it at least once a year. I suggest a good 5w-40 to protect the bearings, and you find something better than the Ravenol VST 5w-40 let me know.
Born 02.27.2015 in Dingolfing
      06-17-2019, 12:11 PM   #5
induc916
Drives: 2014 M6
I change every 3k, using Liquid Molly 5W40
14 M6 Sakhir Coupe | Pure S1 | JB4 | Meth | Fabworx DP | 4mm bored throttle bodies | SSP-R | Billet Diff Mount | DSS Axles | Rkautowerks carbon charge pipes | CSF Intercoolers |Akro exhaust | Gapped Plugs | project-gamma intakes | DME Stage 3+ Custom | 749whp/789wtq
      06-17-2019, 02:10 PM   #6
lotus49
England
9
Thank you all for your replies.
I am convinced. It can't do any harm to change the oil and filter more often than recommended and also to know for sure that the oil is both good quality and the right rating (which is 0W30 here in the UK). I have booked it in for an oil change this Friday.
I can't see myself changing the oil every 3000 miles (good oil isn't cheap) but I shall certainly be doing it more than once every 24000 miles.
      06-18-2019, 05:17 AM   #7
OneExtra
Drives: 2016 M5 Competition
I do mine every year or 5000-6000 miles. BMW Main Dealer change and it costs 190ish plus its recorded in the iDrive
      06-18-2019, 09:03 AM   #8
M5theonlyone
Drives: BMW M5
2013 BMW M5  [5.00]
Same here every year, that BMW MD stamp and i/d record is worth more than from different garage.You can even supply your own oil so long as its Bm approved.
Your oil, then 73 for labour inc. the genuine oil filter.You also have the free multi health check VHC to make sure the car is safe.
      06-18-2019, 10:33 AM   #9
lotus49
England
9
I was going to go to a local mechanic but I was expecting it to be about this much anyway (oil is expensive) so if it's that much at a main dealer, I think I'll call mine and check. Thank you.
      06-18-2019, 10:50 AM   #10
OneExtra
I do mine every year or 5000-6000 miles. BMW Main Dealer change and it costs £190ish plus its recorded in the iDrive
You may be quoted anything up to £300+ so you need to negotiate or phone a few
I bought my own oil and filter from their parts dept and then just paid the labour
      06-19-2019, 03:22 AM   #11
lotus49
England
9
You may be quoted anything up to 300+ so you need to negotiate or phone a few
My main dealer quoted me 206 which doesn't sound too bad. Interestingly, he went on at some length about the last service and how there was no need for an oil change but I've booked it in anyway. It can't do any harm and the consensus here definitely seems to be to change the oil more often than minimum recommendation. Unfortunately, a straight oil change won't show on the iDrive apparently, but I'm still having it done.
      06-19-2019, 07:26 AM   #12
OneExtra
My main dealer quoted me £206 which doesn't sound too bad. Interestingly, he went on at some length about the last service and how there was no need for an oil change but I've booked it in anyway. It can't do any harm and the consensus here definitely seems to be to change the oil more often than minimum recommendation. Unfortunately, a straight oil change won't show on the iDrive apparently, but I'm still having it done.
It will show on the idrive if you insists mine was added to the history section of the service history but the time to go until next oil change was left
      06-19-2019, 10:56 AM   #13
lotus49
England
9
That's interesting. I'll ask them when I drop the car off on Tuesday. Thank you.
      06-25-2019, 01:27 AM   #14
mrtt
Drives: E46/E60/E92/F10/E55
Hell I would go and change out all the fluids if you don't know when they've been replaced last
      06-25-2019, 02:37 PM   #15
lotus49
England
9
The brake fluid service was done just after I got the car. As I mentioned, the recommended services have all been done at main dealers so the oil was changed but about 8000 miles ago.
My local main dealer did the oil change today and it cost me 205. That's not too bad bearing in mind that the oil alone would account for more than half of that. The dealer said several times that it wasn't due and wasn't necessary but I feel better for having done it. It can't do any harm and 200 is a lot cheaper than a new engine.
      06-26-2019, 10:06 AM   #16
OneExtra
Did he update the idrive?
