07-17-2018, 05:46 AM | #2 |
Rep 224
I'm currently running a stage 1 tune.
Pros are its faster, more responsive, pops and bangs more. Cons... have to flash it back to stock before going to the dealer lol |
07-17-2018, 06:19 AM | #3 | |
Rep 1,847
Is it a better car now or is traction more of an issue Evolve do a map you can load yourself and remove as required but its expensive for what it is |
07-17-2018, 10:12 AM | #4 |
Rep 224
I went bootmod3 in the end. I wasn't fussed about pushing it too far and I was catless at the time so just wanted rid of the cel, cold start and the price was really good! The car feels such a slouch without the tune and traction isn't really an issue, well not any more than usual if that make sense, its a quick car stock so you can't just put your foot flat to the floor and hope it'll be alright in most situations without the traction control going nuts. So I'd say its a better car. Not done any 0-60 or dyno runs either
OneExtra809.50 |
07-18-2018, 02:36 AM | #6 | |
Rep 224
Where abouts in the UK are you? I am down in Southampton |
07-18-2018, 03:14 AM | #7 | |
Rep 1,847
Only issue is they don't show what the power increases to, also would want to know if they have fixed the issue with the ECU counter increasing when you change maps. |
07-18-2018, 08:49 AM | #8 | |
Rep 948
07-19-2018, 03:24 AM | #9 | |
Rep 224
edit: here is the thread https://f10.m5post.com/forums/showthread.php?t=1337143 Last edited by dsmclark; 07-19-2018 at 03:55 AM.. Reason: add link |
OneExtra809.50 |
07-19-2018, 03:24 AM | #10 | |
Rep 224
OneExtra809.50 |
08-15-2018, 09:58 AM | #11 | |
Rep 240
makes no odds they can tell straight away pal when they plug it in, via fasting Data and the car throws the DME manipulation code. |
08-15-2018, 10:01 AM | #12 |
Rep 224
have been to the dealer twice and they haven't said anything yet. But time will tell if I ever have a problem as yes chances are they will see something was up
05-17-2019, 05:33 PM | #13 |
Rep 137
I'm researching on a stage 1 tune aswell.
Very tricky as I want something very easy to install and remove any time(so can't do jb4) I haven't got a laptop. Was interested in open flash as they have a handheld device but they have some negative reviews. Ideally, if I want a handheld device off the shelf map or a map that can be installed via my mobile. |
