05-05-2019, 01:55 PM | #1 |
Rep 103
ProMeth Pumps/Fittings/Nozzles
https://prometh.com/collections/pump...=3080363507736
Flows a bit better than the standard DDP5800 pumps https://prometh.com/collections/nozz...18900547862597 The nozzles have internal filters https://prometh.com/collections/nylo...19283720372293 I like the idea of the steel braided teflon hose versus plastic tubing for methanol delivery Anybody already using their products? I've seen KMORGSM5 Post some pictures of his car with their gear |
05-05-2019, 05:08 PM | #2 |
Rep 248
I'm running their stuff, can't complain love it AutoCouture did the install also using their c5 tank they made it hidden for me
I'm told Autocoture made a kit (M5/M6) so they know what fittings and length of lines since mine was the mold if you will. I have mine run into the CSF intercoolers and the solenoid is on a custom bracket on the radiator mount.
05-05-2019, 06:25 PM | #3 |
Rep 103
Dope I'll hit them up! Thanks
I just got my CSF intercoolers on Friday too! Not sure how much of a difference there will be between the M6 coupe and the M5 sedan. I might use the BMS F10 stealth tank with the prometh pump and fittings Last edited by Chaman; 05-05-2019 at 06:51 PM.. |
