      05-10-2019, 09:14 PM   #1
Chaman
Drives: 2015 M5 CP
Dodge Viper thermostat
Anyone running motorad 880090 thermostat ? Seen this recommended by engine builder Troy Jeup and seems like a good idea for those engines.
He also mentions running it on the s63
Curious if anyone here is doing so
      05-11-2019, 04:34 AM   #2
Craze
What for?
      05-11-2019, 08:57 AM   #3
induc916
Drives: 2014 M6
Yeah why I have no issues with heat in my car whats the point of changing this out?
      05-11-2019, 09:38 AM   #4
Chaman
Drives: 2015 M5 CP
Engine oil needs to reach at least 212f to be able to burn off condensates etc and if the engine/oil can't do so then your oil suffers. If your oil suffers, your engine suffers. If the oem coolant thermostat opens at 179 then the engine is taking longer to get the oil to that 212. If you replace the tstat to a 190 then you reduce that window and in a street car the engine can potentially get to temp faster.
      05-11-2019, 11:08 AM   #5
mrtt
Drives: E46/E60/E92/F10/E55
and why would our engines not reach 212 degrees?
      05-11-2019, 01:07 PM   #6
Chaman
Drives: 2015 M5 CP
I think it's more about getting the engine up to operating temperature faster.
      05-12-2019, 11:27 AM   #7
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
Well that has being improved in the F90 it really get the temp up rapidly..!!!
      05-12-2019, 11:34 AM   #8
94jedi
Drives: 2009 e92 M3
Since it's pretty much the same engine, would be interesting to know the part number on that f90 tstat.
      05-13-2019, 08:09 PM   #9
Chaman
Drives: 2015 M5 CP
What temp does the f90 thermostat open
      05-16-2019, 10:06 AM   #10
induc916
Drives: 2014 M6
Any update to this. i also see Jep mentioning running 5w50 redline oil weight.
      05-16-2019, 04:34 PM   #11
Chaman
Drives: 2015 M5 CP
I’m going to call Troy to try to get a better answer on it.
94jedi829.00
      05-16-2019, 11:02 PM   #12
94jedi
Drives: 2009 e92 M3
ask him about oil too lol. Let us know!
      05-18-2019, 10:33 PM   #13
Chaman
Drives: 2015 M5 CP
https://www.instagram.com/p/Bf0-uyXhwix/?igshid=u6jxfku2wbvg
94jedi829.00
      05-20-2019, 06:33 PM   #14
94jedi
Drives: 2009 e92 M3
He kind of skips over the s63TU but I have heard him mention 5w50 in the past as well. Thing is, he's in the midwest (michigan?). My M5 has been and, God willing, will always be an NC car, garage kept so it never has to come up to temp from excessively low temps. I'll listen to his perspective on 5w50, just not sure it makes sense to swap oil given my climate/location. Maybe does...not sure at this point but I have an oil change coming. Keep in mind that our cars are turbo too, So there's a lot more heat involved. that extra weight might help things out. Again, not 100% sure, but it makes sense to me.
      05-21-2019, 06:25 AM   #15
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Just a quick google check and the m5 thermostat is electric and the viper one isn't. ��
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
      06-02-2019, 03:13 PM   #16
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
Sportplus water 83-89
      06-05-2019, 08:10 AM   #17
Chaman
Drives: 2015 M5 CP
https://www.ecstuning.com/b-hamburg-tech-parts/performance-thermostat-90c/11537586885-90c~/
After talking to Troy here is the correct thermostat for s63
      06-05-2019, 12:27 PM   #18
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Thanks for the link! 👍
