10-04-2021, 08:12 PM | #1 |
Rep 538
how much oil are you all putting in?
Did oil change for the first time. Pretty easy, though the filter is messy on removal. How much oil are folks putting in? I've seen lots of quotes of ~8.9qts but what Newtis shows (below) is 9.5L, which equates to 10 quarts.
Filling capacity, engine oil change with oil filter element Liter 9,50
10-04-2021, 08:41 PM | #2 |
Rep 537
I've done it about 3 times myself. I always put in 9qt. (some in filter housing) and it gets the level to just above middle.
I'm assuming 9.5qt. would be just to the top, but I prefer to measure first at 9qt., then adding more in a week or two as needed. I would NOT add 10 qt. |
10-05-2021, 12:29 AM | #3 |
Rep 644
I've changed my own oil at least a couple of dozen times. I have little to no mess due to a Weistec filter drain cap. This is one of those "Must Have" mods especially as a DIY'er.
I would agree with M5_Raz, don't add 10 qt. of oil. The gauge doesn't show if you go over the max which is very bad for your engine. I usually allow the oil to drain for multiple hours changing the pitch of the jack stands every few hours. This ensures a full drain including the intercoolers that hold roughly 1-2 qts. Even with this process, I'll never have to go beyond 9.5 qts to get to the max mark. |
m5rosco210.50 |
10-05-2021, 03:23 AM | #4 | |
Rep 537
Good point about leaving the car jacked up for about an hour, a lot of oil trickles out from the coolers. |
10-05-2021, 06:27 AM | #5 |
Rep 538
Thanks all. I ended up with 9.5qts in. I started with 9qts and level was still low after a quick drive and a measurement, so added another half. Didn't want to add the other 0.5qt until I have more clarity.
I'm wondering, though, if the reason why people used to quote 8.5L and newtis shows 9.5L is related to BMW doing the TSB in late 2013 for adding 1L extra on the regular N63s due to oil consumption, and although the S63Tu isn't mentioned, ours got updated as well. It seems very unlikely that newtis would be incorrect. TSB SI B11 01 13 (yes, it states9.5qt below, but I believe that's sump capacity, the filter/filterhousing is another 0.5qt) "PROCEDURE Engine oil: Topping up When one of the above vehicles displays a message to add 1 quart of engine oil, BMW recommends adding 2 quarts of engine oil instead. The engine’s oil sump design allows the additional quart; the result is a total capacity of 9.5 quarts (9.0 liters) of engine oil. Engine oil: Maintenance services and engine repairs When performing all future engine oil maintenance services and repairs that require draining and refilling the engine oil, the new recommended refill specification is 9.5 quarts (9.0liters) of engine oil. The current version of the oil capacities chart, in Group 11 of the Operating Fluids Manual in TIS, has been updated as of 3/2013 Last edited by vafan13; 10-05-2021 at 08:27 AM.. |
10-05-2021, 10:53 AM | #6 |
Rep 19,245
Same here I let it drain for about an hour with the car angled backwards on wheel blocks.
You can leave the oil drain plug in loose to avoid dirt blowing in through then unscrew to let the remainder out. |
10-05-2021, 01:18 PM | #7 | |
Fueled by Recycled Dinosaurs!
623
Rep 1,162
Drives: F06 M6
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vision, CCB, RKAutowerks Forged Rods/Pistons & E85 DI Exhaust Cams,Carbon Fiber CAI & Billet Diff Brace, Infinity Design CF Turbo Inlets, Swaintech Coated DPs, Mishimoto Oil Cooler, JB4, XHP S3 Flash, Bootmod3
10-06-2021, 05:25 PM | #8 |
Rep 249
Leaving it that extra hour to drain gets between 0.75 and 1.0 litre extra oil out. I measured it as I was curious to see. A dealer (or most garages for that matter) wouldn't do that!
10-06-2021, 05:57 PM | #9 |
Rep 537
It's interesting, I heard that Porsche oil changes at the dealerships are so expensive because they leave the car up on the lift to drain for about an hour or two.
And because the lift is in use, they charge the person as if it's being worked on. Not sure if it l true or not, but it reminded me of this. |
10-10-2021, 09:29 AM | #10 | |
Rep 71
I understand an oil change can be argued to be different but I would still call BS on this if someone pulled that on me. If the job requires this, then they need to invest in more lifts, which are not that expensive in the long-run. If they don't have the space, they shouldn't be a dealership. I am sure someone who worked in a dealership will respond and say it doesn't work that way though! LOL
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
11-28-2021, 09:47 AM | #11 |
Rep 23
01-23-2022, 12:05 AM | #12 |
Rep 1,232
Just did my oil change, and TIS calls for 9.5L. What was weird I put about ~8.3L, I ran the oil measurement from the CID menu and showed is at the MAX, ran again just to be sure, still shows at MAX. Then I remember that ISTA+ has actually testing procedure that measure the oil level and tells you if you need to add any. To my surprise, it asked to add additional 1.2L which came right on point with TIS. Re-ran the procedure and wasn't asking for any additional oil
for those interested here is the TIS link -> https://www.newtis.info/tisv2/a/en/f...ngine/GIXXgkBH |
02-11-2022, 04:02 PM | #13 |
Rep 145
Do y'all change the filter housing o-ring at every oil change?
02-11-2022, 04:49 PM | #14 |
Rep 537
02-11-2022, 06:50 PM | #15 |
Rep 145
5k or about once a year. Reason being is that I just did an oil change a few days ago, didn't change the o-ring, and today saw a drop of oil on the ground, and some around the edge of the hole in the belly pan. I thought I had cleaned up all of the residual (dropping the filter is messy) but maybe I missed some and it's finally worked its way out. I ran my finger around the filter housing today and it seemed dry. Who knows, I'll keep an eye on it.
02-12-2022, 09:35 PM | #16 |
Rep 1,232
Any reason why you didn't? New o-ring comes with new filter and only takes 30secs to replace it. I can't believe BMW went with that design having the cap on the bottom of the engine making changing the filter such a mess. I installed one of those Weismann filter caps, so let see next oil change if is as clean as I would like to be.
