02-06-2016, 05:31 PM | #1 |
Rep 119
Owner's experiences with BMS JB4.
I recently picked up a CP '13 F10 BMW M5. Looking for the best bang for the buck without compromising reliability. The car currently has ~45k miles. I'd like to see 100k miles, or ideally 120-150k. How does the BMS JB4 perform? Are there any 0-60, 60-x or 1/4 numbers to compare stock vs. BMS JB4 only? Have you seen any degradation in reliability? Thanks.
02-08-2016, 10:54 AM | #2 | |
Rep 2,080
Ecu tune is arguably "safer" but hard to quantify. The jb4 "tuning" concept has been around for years with reliability when following guidelines. Ecu tune is great, but involves drilling your ecu to gain access. On a lease car I would do it, but not on a car I own. Not worth the risk even though it's tiny. Dealers and BMW NA know you need to drill the ecu. They can easily check if they want to - more easily than they can detect JB4 as I've been told by the head tech of my local dealer who is my family friend. With all tunes, the likelihood of needing more frequent oil changes, spark plug replacement and injector replacement goes up from my experience. Your and others mileage may vary but I've owed 6 tuned BMWs since 2008 - several different models both with piggyback (jb4), ECU tunes, and both combined. |
02-08-2016, 11:04 AM | #3 |
1090
Rep 1,968
02-08-2016, 11:09 AM | #4 | |
Rep 2,080
With and without jb4 you hit roughly the same boost from idle to 3000 rpms vs say 5000 rpms with the jb4. That's been my seat of pants impression and dyno experience at least. |
02-08-2016, 12:39 PM | #5 | |
Joint Chiefs of Staff
4922
Rep 115,999
Mike |
02-08-2016, 12:43 PM | #6 | |
1090
Rep 1,968
Once the DME load target is reached (typically 2.8K to 3K), JB4 will be additive, so if the target is 15psi and you have +3 on the JB4, car will try to hit 18psi. |
02-08-2016, 01:08 PM | #7 | ||
Rep 2,080
02-08-2016, 02:31 PM | #8 | |
24348
Rep 191,145
If you are going FBO, get the JB4 JB and JB4 are proven to be safe tunes, no need to worry about reliability
02-17-2016, 07:44 PM | #9 | |
Rep 201
The car is now an absolute monster.. It pulls insanely hard, however just be aware that if you go with the bms and eventually bump up the psi - on the oem rubber, it doesn't hook until about 60.
'10 FBO GT-R, ‘17 6.2 Z71 Silverado, ‘14 Cls63 Amg-S, ‘18 991.2 Turbo S, ‘12 458 Italia.
10-01-2021, 02:47 AM | #10 |
Rep 99
Drives: BMW F10 M5
I have purchased the JB4 Tune and I was wondering what everyone had with the overall experience and the horsepower gains... I have a BMW F10 M5 and I have catless downpipes, one of the best cold air intakes out there and a muffler and resonator delete. What are recommendations for me on this set up?
10-02-2021, 08:48 AM | #11 |
Rep 178
I have ECU tunes from Evolve and BPM. The Evolve tune is wild but makes too much torque low down for my liking - over 1000nm at about 3.200 rpm if I recall correctly. The BPM tune is a torque limiting tune which is preferable for everyday driving. JB4 is an option of course but I’ve just popped the motor on my n54 335i running the BMS 500 hp package (which includes a JB4) so while it has inbuilt safety features, it is by no means fail proof. I’d go with an ECU flash from one of the reputable tuners on the forum
10-02-2021, 11:17 AM | #12 |
Rep 242
I run JB4 with BM3 stage 2 93Oct. The only reason I added the JB4 is to compensate for the boost drop due to aftermarket chargecooler, Terry helped me fine tune it to match what BM3 boost curve suppose to be. In addition to a killer map (26 PSI) provided that I can keep the car on the ground lol and I do agree with ajm55 a tune is what you should go for
10-03-2021, 05:47 PM | #13 |
Rep 185
I currently run jb4 on map 1 pulls hard above 5k rpm. Maybe it’ll be quicker when I attach the bcm. But your limited to around 620whp it seems like without going to an actual tune or install a meth kit. I have an aftermarket warranty still for 2 more years which is why I didn’t flash it. Mhd and trans flash for the price seems to be the best deal and no drilling of the Ecu.
