      06-20-2021, 08:20 AM   #1
celicatoe46m3
Drives: E60 M5 & E46 M3
Pre-LCI headlight replacement.
My headlight on the drivers side is beginning to crack. If I find a replacement, will I need to code it at the dealer? Or can someone do it remotely?
      07-01-2021, 01:20 PM   #2
ruben356
Drives: F13 M6 _ San Marino Blue
I believe as long as you swap over the 4 control modules from the cracked light should be plug and play.
      07-02-2021, 09:43 PM   #3
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
The headlight module is the brain, it should be carried over from the original headlight. BUT when I bought a complete used headlight, my Indy said it worked without programming and the module was from the doner car.
