11-30-2021, 01:52 PM | #1 |
Cole
319
Rep 498
Massive suspension improvement
I was so impressed with the results from the suspension work that i jist had done that I felt obligated to post it.
My 2016 m5 CP has 58k miles on it. The lower control arms looked fine, didnt really show any visible cracks in the bushings, but the suspension just didnt feel tight so i had the shop replace both lower control arms. Man, let me tell you, the difference between 58k mile control arms and new oem control arms is night and day. Feels tight, quiet, and smooth. I am seriously blown away so anyone who hasnt changed theirs at 60k should seriously think about it |
11-30-2021, 04:50 PM | #2 |
Rep 19,422
Someone else over here with a CP with 16k miles had a steering wobble and knock braking from speed, was going back and forth to BMW when eventually they found it was one of the lca's. Faulty one replaced under warranty and he paid for the other one to be replaced as a precaution.
11-30-2021, 09:42 PM | #3 | |
Cole
319
Rep 498
I also had steering wheel wobble whoch everyone kept blaming on the wheels. Its all gone and smooth now. Pretty expensive for both, but worth every penny. |
12-01-2021, 02:14 AM | #4 | |
Rep 19,422
12-01-2021, 10:56 PM | #5 |
Lover of the 3rd pedal
70
Rep 103
Drives: '16 M5 6spd; '13 Audi S4 6 spd
Need to have mine looked at. 55k on my '16 CP that I bought two years ago with 44k. Now, it does have Dinan coil overs which make it even more firm…probably firmer than I like in LA traffic (and w/ 6sp manual).
12-13-2021, 03:51 PM | #6 |
Rep 189
do y'all live in areas with thrashed roads? Trying to determine if BMW is cheaping out on suspension or if external conditions are contributing to your suspension components wearing prematurely.
12-14-2021, 10:01 AM | #7 | |
Cole
319
Rep 498
The dealership techs told me that they change them frequently on most BMW models. Seems like a lot of load on one critical suspension component and over time inevitably will wear out. |
12-14-2021, 11:33 AM | #8 |
Rep 538
it's too bad OE versions aren't available. the BMW-branded are darn expensive.
12-14-2021, 11:36 AM | #9 |
Cole
319
Rep 498
12-14-2021, 01:58 PM | #12 |
Rep 19,422
12-14-2021, 05:08 PM | #15 |
70
Rep 103
Bought my '16 CP two years ago and purchased it site unseen (manual transmission). It was CPO'ed and when I brought it into the dealer in LA they figured out it has Dinan coil overs. It rides hard as you'd suspect. I'm not sure if all sets are adjustable but if they are I think I need to raise it slightly back to the CP level. Feels like it may be another 10mm lower than CP.
Front photo doesn't do a great job of seeing that. |
12-15-2021, 06:50 AM | #17 |
Rep 19,422
That's asking, best to go to your dealer for that, the front lower competition arms appear to be vastly more dear due to their limited numbers with harder mount rubber inserts and special chassis set up points.
12-15-2021, 10:30 AM | #18 | |
Rep 538
and what do you mean by "special chassis set up points"? To answer the part number question, lower control arms are 31122284977 (L) and 31122284978 (R). the newtis manual states that if one installs the newer LCAs on a pre March 13 car, one must also update the thrust arms. My guess is it's preferred, but not truly necessary. It also says an iSTEP update is necessary if it's below a certain version (probably march '13, but I forget exactly).
12-15-2021, 11:29 AM | #19 | |
Rep 19,422
12-15-2021, 12:13 PM | #20 |
Rep 538
well now I'm curious. is there a current example you could link?
12-15-2021, 12:25 PM | #21 |
Rep 464
Hey guys
I was under the car today and was able to get the part numbers on the control arms. Please see photos I also have a 2014 m5 COMP [IMG][/IMG] 31122284675 is the same as 31-12-2-284-977 ( left side ) 31-12-2-284-978 ( right side ) |
Doctor_X1158.00 |
12-15-2021, 01:36 PM | #22 |
Rep 19,422
Yer tis, same arm for front lower, fits standard one but not comp.
