11-03-2020, 12:38 PM | #1 |
Rep 835
Idle Problem - Can anyone help?
Sorry for the long post, appreciate anyone reading to give me advice...
Hi all Imposter here from the M6 side, but that side is quite quiet so I hope you don't mind me asking here as it's going to be relevant to both. As short as I can - purchased F13 M6 couple months ago, great car, mildly tuned but not engine itself, just intake really. Runs great in general and being new to this engine/car I didn't notice anything terrible on the test drive. One thing I have done since ownership is do a cold start delete which has served to highlight this issue more, but I'm 99% sure the issue was there all along. So, the issue - On cold starts, i.e. when starting after sitting overnight, id seems to start and rev correctly. Then after about 20 seconds, it starts idling roughly, the revs drop and then it recovers by surging and then this repeats a number of times, for about 30-45 seconds. Here is a clip I recorded the other day, sometimes it's worse, but this gives a good idea. Please watch with sound too https://www.youtube.com/watch?v=UXlJaj0tL6k When the revs drop you feel it in the car. When trying to drive during this time it kangaroos like crazy, I have to wait for it to settle. Until recently I thought it was only during startup but now I think that when I come to a stop at any time, the idle is not as smooth as it should be, the needle does move slightly and what's even weirder is that when creeping along before stopping, as soon as I brake the revs go up over 1k quickly then quickly drop back down. All a bit strange. (that part could be normal though). All I have done so far mechanically is a MAF sensor change. In terms of mapping, I have been running Bootmod3 however I am currently back on the stock tune and it's still doing it. With the cold start function ON, although the revs are higher, they are still not stable like I would expect, though its less noticeable than with cold start off I admit. Oh an no error codes are thrown at all. Basically looking for advice on next steps. I have ISTA, should I be looking at doing any specific diagnostics tests? My next action is to replace plugs and coils because I just like to know they are refreshed, but I'm not just assuming that will fix my problem. Any advice would be great as it's one of 2 issues that are ruining the enjoyment a little (I'll post the other one separately!) Thanks for reading |
11-04-2020, 11:35 AM | #3 | |
Rep 107
As per the previous post, I would suggest cleaning the MAF (both). It seemed to have solved the issue for me for a while, but recently I am getting the erratic revs again. I put the car on the computer and all was perfect. So barring changing the MAF, I am lost. |
11-05-2020, 05:59 AM | #5 | |
Rep 107
Personally I would try and find a independent M specialist to get their opinion. Defo a concern when nothing is showing on the computers... Keep me posted. |
11-30-2020, 10:51 AM | #6 |
Rep 242
Does the RPM drop to below 500rpm when stopping nearby a traffic light? or after keeping the car on for a while? or when you turn the steering wheel to the max(left or right doesn't matter) in a stationary position?
11-30-2020, 10:52 AM | #7 |
Rep 835
drops on hard lock left or right, surges when coming to a stop and drops when actually stopping. I've done a lot more work on this and still not come up with the answer
11-30-2020, 06:28 PM | #8 |
Rep 242
Share WOT datalog but from past experience, there is a slight air leak.
If you ever changed the filters or removed the airbox check the boots as they have guides it may not be seated correctly, check your charge pipes and using BM3 keep your cold start at 1100 RPM. Also, reset adaptations & relearn Valvetronic limit position through ISTA. |
12-01-2020, 01:50 PM | #9 | |
Rep 835
I don’t think the boots are not fitted correctly but I wasn’t aware of them having guides, is that on both sides? Setting cold start rpm does not appear to work and BM3 are aware, basically setting the rpm still carries out a cold start as normal, but more quickly dips down so it doesn’t respect the setting on this car it seems. I reset the adaptations a number of times and have also relearned the valvetronic positions (I think) but I could try again. What is the best way other than visibly to check the charge pipes and also, do you know where the best place to insert smoke would be to conduct a leak test on the vacuum side? Finally BM3 suggested there could be a leak between turbos and downpipes. What’s the best way to test for that? Sorry for all the questions! |
12-01-2020, 07:20 PM | #10 | |
Rep 242
