01-05-2023, 03:56 PM | #1 |
Rep 1,360
Paint matching black sapphire metallic
I just had some damage repaired on my 2022 M850i and while the paint color match is very good, the metallic flake is definitely different. And it's different enough that I'm not too happy about it. I see bigger flakes, more flakes and occasional flecks of red in the flakes.
My question is how difficult should it be for the autobody to match the metallic flake? I already told them I wasn't happy with the result, but the manager(?) was quick to dismiss my concerns. I'm pissed that I have to complain and complain just to get action. I can't simply trust them to make it right and deliver me the car without scratched up clearcoat and other issues. Rob |
01-05-2023, 04:59 PM | #2 |
Rep 5,577
Was it a Certified BMW paint facility ?
https://www.bodyshopbusiness.com/off...match-a-color/ " Choose the right size metallic flakes. When matching metallic colors, always be sure that the metallic flake is the proper size. You can actually have a paint color match, but it’ll appear differently than the car because of a mis-matched metallic. Coarser metallic makes the paint look darker, while a finer metallic makes the paint look lighter. When choosing an alternate formula, choose the one with the right metallic that matches your vehicle. " Have no opinion if you should complain or not. BMW M850 certainly isn't a vehicle you have an apprentice work on. Last edited by overcoil; 01-05-2023 at 05:06 PM.. |
01-05-2023, 07:36 PM | #3 |
Rep 1,360
Yes, it is a certified BMW repair center.
I took the car back today and spoke to the manager. Eventually, they somewhat agreed there is too much metallic in the paint, but it's always more a question of what I see, not what they do. They didn't argue about fixing it though so they will be repainting the rear quarter panel and bumper. I just wanted them to acknowledge the issue and just try and do it better. We also noticed big sanding marks and scuffs in the new clearcoat. The car has to go back either way for them to clean it up. At the end of the day, I want to be 'taken care of' and not have to second guess or worry about things not being right. I said get the car back to as close to new as you can. That's all I want. Compare the door metallic to rear quarter. Rear has too much flake Rob |
01-06-2023, 12:12 PM | #4 |
Petrolhead
1942
Rep 3,521
Even if it is a certified shop, there can be issues like you mentioned. How do I know? I've been down that route before. In the end, I just gave up after them trying to fix it twice. I learnt to live with it and ended up selling the car.
That alone makes me want to get non-metallic paint for my cars but yeah.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
Bruuuce341.50 TheMidnightNarwhal2654.50 |
01-06-2023, 04:34 PM | #6 | |
Rep 7,295
01-07-2023, 08:25 AM | #7 |
Rep 2,906
Body shops are a big pet peeve of mine. They are mostly all terrible. No attention to detail.
TheMidnightNarwhal2654.50 Mosaud19983939.00 |
01-08-2023, 12:48 AM | #8 |
Rep 1,360
Well, I guess my question for the experts is should the bumper be replaced or is it ok to sand and repaint? I'm concerned of an impending hack job.....
BMW: "To ensure the system function in vehicles with sensor for lane change warning (optional equipment S5ASA and S5ATA), do not repaint the bumper panel in paint stage 1 or paint stage 3." Rob |
01-09-2023, 08:11 AM | #10 | ||
Rep 780
Just taking a guess considering the lane change sensor probably needs the thinnest coating of paint for it to sense the other vehicle. Personally, on a car that new and valuable I would demand they repaint it. Is the panel metal or plastic? Quote:
Yes, horrible, looks like they found an old can of beach buggy paint from the 70's
2008 E86 M coupe
01-09-2023, 09:24 AM | #11 | |
Rep 1,360
And I do have a big problem with a brand new bumper now having to be sanded and repainted. The car is too expensive to be half-assing it. Rob |
grannyknot950.50 |
01-09-2023, 11:41 AM | #12 |
Rep 5,577
as I see it (and I can't really see things accurately with the pictures) if there were an issue that when viewing the car from the side you can see a difference between the door (which I am guessing wasn't painted ) and the quarter panel (which I assume was painted ) then that is significant. Should the quarter panels be repainted that needs to be thought through.
I'm assuming the clear coat haze in the quarter panel is not too difficult to polish out. I might be nuts but I usually don't do paint correction in a season when there is or has been road salt dispensed recently. That salt takes a few washes to get out off the car and days of rain to get out of the streets. If the bumper is the only piece showing a difference in the flakes but the color is good then that is also an issue that needs to be thought out. Also really inspect the front bumper - I don't know but could the different material of the bumper have an effect on how the flake materials land ? Also when inspecting the new painted pieces look for drips or dirt particularly near edges and mating points. If you don't see any drips or defects then that might tell you that that aspect of the paint job was very well done. But like I said pictures on the computer is a hard format to assess paint quality. |
01-09-2023, 11:51 AM | #13 |
Rep 6,286
I'm not a pro in but my understanding is that it is hard if not impossible to paint match 100%, especially metallic or a perl color. That is why they will instead blend the paint. Extend the paint into the next panel to hide it and make it blend. I thought this was standard practise for like the best jobs.
Also OP the red circle you have circled is not metallic flake, not sure if you were aware and you were just showing us that picture you intended to also show the body shop the holograms. That is hazing/holograms and simply needs to be polished out. |
01-09-2023, 11:58 AM | #14 | |
Rep 6,286
01-09-2023, 03:38 PM | #15 |
Rep 780
I'm also considered "difficult" because mostly I do all my own paint, I was forced into learning to do it myself after being ripped off one too many times by lying paint shops.
However this fall I had to fix a couple of rust blisters in the bird bath trough on the hatch of the Z4MC. Black metallic paint is the true test of a good painter and I wasn't sure if I was up for that test just yet so I fixed rust and prepped the hatch for paint and took it down to my local collision shop with paint codes for Black Sapphire metallic. After they quoted, $500 I mange to spend 10min with the painter talking prep, techniques and equipment, he assured me everything was cool and I would be happy. He was right, a young guy who took pride in his work and he did outstanding work. They used a digital paint colour reader for the shade and the paint code for reference.
2008 E86 M coupe
01-09-2023, 06:49 PM | #16 | |
Rep 1,360
It just feels like this is just going to go from bad to worse. I was preparing to sell the car in October and this has all been just a brutal nightmare for me. There are also no diminished value claims here in Canada. The claim now makes resale almost impossible without taking a massive loss. I will include a pic of the original damage. Rob |
overcoil3073.50 |
01-09-2023, 07:38 PM | #17 |
You got my money?
3150
Rep 4,644
Drives: Ice Cream Truck
It would seem to me that the harsh snow environment probably dulled your stock paint and the body shop paint just looks better with more clarity. Id have someone else do a paint correction on the stock paint to make it look like the new paint the shop laid down. Its probably just that.
Ive had the same paint I thought I took care of well on a former bmw. Then I had it paint corrected and was blown away at home much more flake I saw in the paint. The flake also looked much bigger to me. That might be the problem here.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
01-13-2023, 02:03 PM | #19 | |
Spoiler Bandit
1650
Rep 872
01-14-2023, 06:03 AM | #20 | |
Rep 1,360
They did not answer 1 significant question regarding what the BMW recommendation is for bumper repainting. Obviously they just want to repaint it and call it a day. I should contact another BMW repair center to find out what the truth is. The reply I got: "Good morning Rob I have booked your appointment for January 30th with us and have secured a loaner car with BMW for you we will do everything to make this process as easy and flawless a possible As for the car looking perfect we will make sure that the fleck is as close to factory as possible and will make sure no swirl marks in paint I look forward to making this right and thank you for your business Again thank you" |
01-24-2023, 09:50 AM | #21 |
Rep 1,360
Last weekend my car got hit yet again by another careless driver. He attempted to pull into a passing lane on the left when snow buildup left no room. He was 2 inches from sideswiping me and his passenger mirror made contact with my driver side mirror (damaging it).
I guess it's time to put another claim on my car, even if the damage is minimal. Rob |
overcoil3073.50 |
01-24-2023, 10:48 AM | #22 |
Rep 787
To answer the question asked, it's really hard to match metalic. It's more than just using the correct material, it's also the fan angle on the spray gun, the wrist action as it is being laid down, and the air pressure. All of these dictate how the flakes land and settle on the surface, whether they are flat or at angles. These angles dictate how much the prismatic effect takes place. Unless the repair was done with the same batch of paint in the same gun by the same guy/machine, with the same setup, I'd never expect it to be perfect and be surprised if it was close.
Yes, it's clearly not a good match, but on trade-in it's unlikely to be noticed or dinged in value for the poor match so long as the base material is the right color. That sort of thing is often missed on inspection. |
