01-29-2023, 09:16 AM | #1 |
Rep 1
Load Relative at 50% of Target all around
Hi All,
I've recently had my N13B16A rebuilt in singapore and have encountered a span of nightmares. Car doesn't run properly, misfires and stalls. The following item has been replaced but to no avail. It was first rebuilt due to excessive oil consumption and smoking at idling (Non PCV related). The workshop that did the rebuild has waved the whiteflag citing that they've tried swapping every single part with a working N13B16A from another running car and it didn't help including fuel injectors, MAP, MAF, DME. Pistons, Wossner 9520DA Timing Chain and Timing Guide Valve Seals Top Block surface skimmed Valvetronic Motor Vanos Intake & Exhaust Throttle Body (Jamming after reinstall). Intake Boot Valvecover Spark Plug & Coils Hybrid Turbo HPFP & LPFP + Relay. And probably a few more i didn't list here. Attached is the screenshot relative to throttle position. Full datalog here: https://www.bootmod3.net/log?id=63d4...729bbe20879059 Any help would be greatly appreciated. |
