07-13-2022, 03:05 PM | #1 |
Rep 5
What are the 5 things every new F10 owner should do?
Hey Fam -
New to F10 world, long (long!) time car and forum whore. My experience is that the fastest way to where you want to go is on the backs of the collective experience. What are the 5 things you think every F10 M5/6 owner should do when they pick up a new (to them) car? Example: "change the plugs and coils, install XYZ bar, buy ABC diagnostic cable, buy ... brake pads and insert name air intake" What's the 5 things that give the most quality of life, enjoyment, reliability, etc on the F10 chassis? (can include tune if that's a top 5). |
07-13-2022, 05:15 PM | #2 | ||
Rep 280
Definitely a full fluid change or atleast an oil change, Check spark plugs, coils etc. I'd definitely invest into BIMMERLINK as it's an easy way to diagnose any issues you might ever run into Check all fluid levels as well, coolant for turbos/engine etc Get yourself some catless downpipes |
07-13-2022, 06:59 PM | #3 |
Rep 538
Pull the plastic engine cover off and check for signs of coolant leakage from the lines going to the turbos. Check *both* coolant levels, especially the passenger side one, as that does not have an electronic sensor. Do an oil change and while you're down there, look for leaks from the oil and trans cooler lines and pans for each.
If you're going to check the plugs I'd just get new ones (along with new coils). It's not the quickest/easiest job so if you're pulling them, might as well put new ones back in. As far as upgrades, for me the Dinan sways made a huge difference in making it feel less like a boat. For M car parts they aren't that expensive and if you're at all used to doing work on cars they aren't hard to install. Last edited by vafan13; 07-13-2022 at 07:05 PM.. |
07-13-2022, 08:11 PM | #4 |
Rep 648
Hear's my 2 cents (in this order)
1 - Perform an oil change and submit a sample to Blackstone for an analysis report. This will give you a baseline on how healthy your engine is. Use the report to develop a schedule for oil changes in the future. 2 - Perform any required maintenance work that's either close or overdue. If you have excessive squealing from the brakes, swap out the pads for CarboTech 1521's 3 - Consider an aftermarket warranty. Check the forum threads for who to go with. There's plenty of info out there. 4 - Consider a professional detail including ceramic coating and PPF the front bumper, fenders and hood. This is my only regret that I didn't do on my car. It's time to repaint the front bumper which will cost roughly about the same as if I did those items mentioned above. 5 - Last but not least. Enjoy the car in its natural state before doing any cosmetic or performance modifications. I have plenty of mods, but I took my time and strategically mapped out what I wanted. |
co_pa223.00 |
07-14-2022, 04:28 AM | #5 |
Rep 19,524
Don't know about five things but car should have history with it so if oil was done recently there's no need to change just for the hell of it. What grade you use is a difference of opinion on here but I stick to 0W40 Edge A3/B4 rating or others with the same. It doesn't have to say BMW approved on it.
Ppl tend to change plugs too frequently when there's no need, its a tricky job and mine were not changed until 40k but then I don't hammer mine a lot of the time but if it's tuned then you will have to change them more frequently with a more reduced plug gap from the standard 0.032. Think twice before changing DCT fluid as it's for life, change diff oil every 20-25k and don't forget the air filters. Coolant in both reservoirs change at 100k with distilled water and BMW a/freeze with 50/50 mix. |
pleadbymail88.50 |
07-14-2022, 09:07 AM | #7 | |
Rep 80
You may be getting a car with worn brakes or tires, or the wipers are shot… make a check list for yourself the same as you would for a Camry. My car had weak cool ac which I believe is a bad condenser, maybe I'll address it one day. |
M5Rick60013.50 |
07-14-2022, 09:20 AM | #8 |
Rep 5
We're missing the spirit of what I was after here. This has turned into a maintenance thread.
What I'm trying to get after is: "what are the 5 best things you can do to maximize your F10 M5 experience" What are the must have mods? What makes driving an M5 the most rewarding ? I've got new plugs, coils, brake (pads) and no codes. I'm hope to skip the learning curve and maximize my experience. What should I buy / do first? What coding mods are most rewarding? What is the go to tune? What suspension or cooling mods are must have? Etc. |
07-14-2022, 09:21 AM | #9 | |
Rep 19,524
07-14-2022, 09:25 AM | #10 | |
Rep 19,524
fstm5145.50 |
07-14-2022, 11:45 AM | #11 |
Rep 538
Nobody here missed the point, they all followed your example. Why don't you do the research on the mods you want instead of following others?
Mods are about preference. I love catless downpipes but the next guy hates them due to the smell, etc. |
07-14-2022, 04:33 PM | #12 |
Rep 250
First, maintenance. Service it even if the previous owner did it last week. This way you will know the oil/plug/coils are fresh and will remain problem free.
Second, Remap. Stage 2 (so map and decat) is my preference. This really wakes the car up and turns it into a supercar eater. Lower it a bit. KW HAS springs get my vote. These can be adjusted to give whatever ride height you desire, yet retain the electronic damper control. Fit Michelin PS4 tyres. If the car isn't a competition pack car, a comp pack anti roll (sway) bar makes a massive difference to how the car corners. Bimmerlink and Bimmercode a very handy apps to have to check and clear codes, and code things to your liking and only require a cheap dongle and an app. Get the car properly detailed and ceramic coated. Intakes don't really offer any performance gains, but do offer more noise and better looks but this is all subjective. The stock exhaust sound really good when coupled with decayed downpipes. If you do change the exhaust then an Akrapovic is the best you can do! It's just loud enough without being too loud, gives a really nice exotic tone and does not drone! If you keep the stock exhaust consider changing the tips to something beefier as the stock ones are a bit pathetic! Sorry that's more than five! |
Endless Summer0.00 |
07-14-2022, 05:44 PM | #13 |
Rep 5
Love that ^^
That is the spirit of what I'm after. Car is a comp, new plugs and coils, new PS4s (265/295), stage 1 (dyno comp custom tune here in AZ), full clear bra front end + ceramic. Seems like I'm half way there so far! Nervous about stage 2 and decat - I have a long history of "tune it til you ruin it". Don't want that experience here. |
07-17-2022, 12:17 AM | #14 |
Rep 171
1. Blackstone Labs oil analysis
2. Plugs and coils if 20K miles have past since last change 3. Soul resonators to replace mufflers (or any exhaust mod because stock sucks) 4. MMI CarPlay 5. KV3 coil-overs (good to do at 50,000 miles or so vs. replacing stock struts; you will not miss EDC) Last edited by MFM5; 07-18-2022 at 08:54 PM.. |
07-17-2022, 05:14 PM | #15 | |
Rep 5
07-18-2022, 07:07 PM | #16 |
Rep 171
https://www.bimmer-tech.net/category...y-mmi-retrofit
$699 for Apple or Andoid kit. I had it installed for $150.
'15 Monte Carlo Blue M5 (daily) | '09 GT Silver 997 TT Cab 6-speed
'14 Agate 991 C4S -- sold | '15 Shark Gray Z06 -- wrecked '08 Silverstone M3 -- sold | '06 Artic Silver 997 C2S Cab -- sold '09 Black Challenger SRT -- sold | '98 Artic Silver M3 -- sold |
07-21-2022, 03:04 PM | #17 | |
Rep 396
also, i agree w/ you, over-modding is a personal trait and have set my tolerance level at stage 1 w/ intake and exhaust. this car doesn't need stage 2 to be a fucking riot to drive. mmi is on deck to be my last mod. would have done it by now but eyeing a g80 purchase first.
current: 23 g20 m340ix
08-21-2022, 01:41 AM | #18 | |
Rep 37
My brakes definitely squealing and they're fairly new oem pads, are the carbotechs the overall best option to stop this? what causes it? |
