      06-20-2020, 10:50 PM   #1
rickyf10
rickyf10's Avatar
Umnitza headlight error coding fix
just installed the set of umnitza LED headlights to replace my xenon ones. after coding LWR_AHL_TYP to ohne and FLC_AKTIV to nicht_aktiv as i read elsewhere, i still got "cornering lights malfunction" for both sides.
so i did some research on the forum but no help. fortunately, i found the fix myself apart from LWR_AHL_TYP and FLC_AKTIV, there is extra coding work needs to be done.
simply set all of these below to nicht_aktiv, malfunction gone.
AUSG_09_FL_WARM_UEBERW_AKTIV
AUSG_09_FL_L_KALT_UEBERW_AKTIV
AUSG_10_FL_R_WARM_UEBERW_AKTIV
AUSG_10_FL_R_KALT_UEBERW_AKTIV
      06-24-2020, 09:47 PM   #2
AlisterB
Nice work on resolving the issue yourself.
Out of interest, do you not get any coding related info from Umnitza when purchasing the headlights?
      06-24-2020, 11:47 PM   #3
rickyf10
rickyf10's Avatar
it's a used set, so no
      07-03-2020, 10:56 AM   #4
boomerang.e92
boomerang.e92's Avatar
Drives: E92 M3
Worked like magic! Thank you good sir!!
      09-17-2021, 08:26 AM   #5
Kandri
Drives: 550i
It worked for me, however when I keep headligth switch on auto light stays on all the time.
Did you have same issue?
