08-29-2019, 10:26 PM | #1 |
Rep 102
Comparison of all different Stage 1 OBD tunes for CP F10
Hey guys,
So I have been thinking about doing a Stage 1 tune on my CP '15 F10 (93 octane and stock exhaust and DPs) and I have been going through posts to find info but there are so many tuners out there that every other day or so I come across a new name. So I am trying my luck here to see if someone has done a post where all tuners are compared for HP and torque gains for Stage 1 tune. Example Bootmod3 vs BPM vs DME vs Dinan, etc.. Whose tune is more reliable, better cost, which tuner provides the biggest gains, etc.. |
09-01-2019, 12:19 AM | #2 |
Rep 541
you are only going to get opinion and personal preferences on this question. do your research and read up on all of them and make an informed decision on what you think sounds best and suits you.
max torque for dct is ~620-650 some tunes just clear CEL's while others code it out (for dp's) etc (but you dont want a Dinan/ piggyback. u want to choose a dme flash option) Last edited by BeachM5nster; 09-01-2019 at 12:27 AM.. |
09-03-2019, 11:09 AM | #3 |
Rep 108
Drives: 2015 BMW M5
I'd be interested in learning more about Steve Dinan's current shop, Carbahn Autoworks and their Stage 1 tune. It can be applied via the OBD port and not having to remove the DME's. And it's not a piggyback like the Dinan product. It's the only tune I've read about for the F10 M5 where they actually talk about not sacrificing your motor for power that you can only see on a dyno.
https://carbahnautoworks.com/product...software-only/
09-04-2019, 10:47 PM | #4 |
Rep 102
I have been doing some research and looks like the average gain with Stage 1 is about 70hp and about 100lb of torque.
I was talking to a local tuner here in VA today and he suggested that besides the tune I should also consider replacing the OEM plastic charge pipes with metal ones and also replace 1 step cooler spark plugs. Any comments on the above recommendation? |
09-05-2019, 10:49 AM | #5 | |
Rep 4,209
Also when you go stage 2, you should look into upgrading your clutch as the stock clutch cant handle ~700 whp. |
09-05-2019, 10:54 AM | #6 | ||
Rep 102
09-05-2019, 11:54 AM | #8 | |
Rep 1,847
Ickdeep5718.50 |
09-11-2019, 08:08 AM | #9 | |
Rep 108
Drives: 2015 BMW M5
I don't need specifics or trade secrets, just tell me from a high level that we keep boost levels, AFR, timing, etc. at safe levels throughout the RPM band, and in particular with this DCT, about what they do to ensure that you don't take unnecessary levels of low-RPM torque to burn up your clutches in 1st through 3rd gear. And certainly the case for a stage 1 tune, you shouldn't need colder plugs or even new plugs all together unless your plugs are near the end of their useful life. (~30k miles give or take.) Like I said above, I really like Steve Dinan and the tune from Carbahn sounds promising and they were the only tuners for the F10 M5 (that I have found) that talks about some of my concerns above. In my experience with tuners from my Corvette days, if they won't take the time to answer your (reasonable) questions, be leery. I don't expect them to teach me how to tune myself, just give me some pertinent details in summary of what they propose to do to my car.
