02-10-2021, 04:03 PM | #1 |
Rep 95
Wanted S63TU ECU pinout
I had a chipmunk apparently make winter camp in my engine bay in the last couple weeks. After clearing out all the crap (that I could find), I'm throwing a couple of CE codes. I bet the little Fkers nicked a couple wires on ECU Bank2.
Anyone have a pinout of the ECU connectors? Cannot find on any searches. Thanks a ton. Steve in Lex
2014 M6 Coupe (SG/Silverstone)
2017 X5M (LBBlue/Aragon) 2000 Z3M Roadster (EstB/Black) |
02-10-2021, 10:19 PM | #2 |
Rep 631
Does this help?
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination Last edited by arucano; 02-10-2021 at 10:28 PM.. |
02-10-2021, 10:57 PM | #4 |
Rep 95
Hmm. I was hoping to see a Fuel Level Sensor or Left Tank Sensor
Digital Motor Electronics 2 errors 193001: FUEL LEVEL SENSOR, LEFT, ELECTRICAL: SHORT CIRCUIT TO POSITIVE 118010: MIXTURE CONTROL, ACROSS BANKS: MIXTURE TOO LEAN Digital Engine Electronics 2 2 errors 193001: FUEL LEVEL SENSOR, LEFT, ELECTRICAL: SHORT CIRCUIT TO POSITIVE 118110: MIXTURE CONTROL 2, ACROSS BANKS: MIXTURE TOO LEAN
02-10-2021, 11:12 PM | #5 |
Rep 95
Now thinking about it... it's perhaps maybe unrelated to the chipmunks. It was super cold the other day when this happened and I dont usually drive this car much. So I may have popped the lean code with dense air (and my tune) and I was also low on gas. So i'll drive it, clear adapatations, pull the air box to make sure they didnt eat my air filters. Maybe it's not the wiring. I'll report back in a couple days
Boosted M568.50 |
02-11-2021, 12:29 AM | #6 |
Rep 349
02-11-2021, 01:19 AM | #7 |
Rep 631
Depending on the series, the signals from fuel level sensor and fuel level sensor 2 are evaluated in the following control unit:
Example F01, F10, F25, F26: junction box electronics (JBE) Example F20, F30: Rear Electronic Module (REM) You can have a look at the level sensor wiring at the tank and work back from there.
02-11-2021, 11:23 AM | #8 |
Rep 95
i guess the A45 DME2 doc does not correlate to the ECU pinout from how i read it
02-11-2021, 03:59 PM | #9 |
Rep 631
This might be better. It is broken up in 6 pieces to make it legible.
M5Dan212.00 |
Tags |
ecu, pinout, s63tu, schematic |
