09-07-2022, 02:22 PM | #1 |
Rep 19
Blown engine
So my f10 m5 with 20k miles on it just blown its engine during track day, only did 2 laps, and no temperature warning/is at normal temperature. Suddenly the engine just stalled white smoke popping from the hood, and viewers said there was large flame coming out of the exhaust, oil leaks under the car and in the engine, water was mixing with oil in the engine.
Possible cause is i did a bootmod3 ots stage 2 tune(i have read several blown engines with this tune in the thread) where before i did a harsher track day with no problems. Another possible cause told by my mechanic is because the installation of new aftermarket intercoolers(which was installed in the previous track day without any problems) which caused a leak or sucking of coolant/water into the engine. Or any other possible leak from whatever its from. My mechanic did say that there was a hint of white smoke from exhaust when i am accelerating hard, was checked and said no problems. Now I need a new engine as I believe it was beyond repair. Any recommendation where to buy one? I stumbled upon ghassan automotive doing refurbished/remanufactured s63 engine. Any one knows them? Any information/input is highly appreciated for this shit situation i am in. Last edited by felfyre; 09-07-2022 at 02:32 PM.. |
09-09-2022, 06:25 AM | #2 | |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
dhm11819.00 |
09-09-2022, 09:22 AM | #3 |
Rep 648
If you mess with Ghassan after reading up on him on this Forum, good luck to you.
RK has great follow up and review from everyone I've talked to. That's who I'll use. I'm just waiting for mine to pop but it seems to keep going. I'm at 160k miles on the stock engine. |
TinCanSailor629.50 1320racer135.00 |
09-09-2022, 07:25 PM | #4 |
Rep 801
Ghassan auto or whatever it's called screwed me back in the day on an N54 engine for my 335i , paying thousands of dollars I would go with a well ranked building especially for an S63 . It sucks your engine is gone at such low mileage but its a situation where it leaves with you a paper weight and there's nothing you can do but swing the cash to get it back on the road , it is a good time to build it and make it stronger though I would try That place is Texas who build these on the daily . Good luck !
14 M5 / comp / CCBs / alpine white
PG intakes Evolve tune Switzer exhaust Fabworx pipes |
09-11-2022, 07:45 AM | #6 |
Rep 1,797
TinCanSailor629.50 M5Rick60013.50 |
09-15-2022, 12:01 AM | #7 | ||
Rep 280
09-16-2022, 12:48 AM | #10 |
Rep 19
Yup, that was the case, no coolant left, but the temperature indicator was normal. Oil was shell 5/30w
09-16-2022, 09:04 AM | #13 |
Rep 19
09-16-2022, 10:24 AM | #14 |
Rep 242
5w-40 is recommended as well, which has better Viscosity and Shear but shit happens specially that your car is tuned.
How many Miles or KM was on it (the oil)? |
09-16-2022, 10:30 AM | #15 |
Rep 19
09-16-2022, 03:00 PM | #16 |
Rep 1,245
There are too many things that could have gone wrong especially with tune and aftermarket parts. If you have trusted mechanic who would do your engine swap, asked them to open the engine and look what could have happened. I don't believe is oil issue 5w30 is spec's oil by BMW and shouldn't have caused it. Again no one here can pin point what exactly caused it without you opening the engine.
M6Roar85.50 |
09-16-2022, 06:41 PM | #17 | |
Rep 112
09-16-2022, 10:05 PM | #18 |
Rep 19
09-16-2022, 10:07 PM | #19 |
Rep 112
No sorry I was asking the guy with 160k miles if he was stock or if he had any mods.
09-17-2022, 04:49 AM | #20 | |
Rep 242
BMW recommended that oil for their stock power(still blow up on stock) not a 100+ hp over stock, 5-W30 has a viscosity of something around 11 by the time he finished his 2nd lap that number dropped. Most blown up engine were running either 0-W30 or 5-W30. Also you are right unless he open his engine all he will have is speculation. |
JayDD007104.50 |
09-25-2022, 05:25 AM | #21 | |
Rep 648
I also run a blackstone report 2-3x's per year. What's interesting is that the report always shows my 5W/40 viscosity is okay but on the bottom range of the envelope for a 5W/40 oil weight. Basically it's telling me that I could possibly run 5W/50 to achieve 5W/40. |
09-25-2022, 07:40 AM | #22 |
Rep 485
A M specialist is currently installing ACL upgrade rod bearings and a new oil pump. He recommended to run 5w50, so I opted for Motul Sport 5w50 this time, instead of Ravenol RUP 5w40. I will post pics of the original bearing shells after I picked up the car next week.
