01-07-2019, 09:08 PM | #1 |
Rep 992
F80 M3 or F10 M5
Hello,
I been going back and forth between f80 M3 or F10 M5. I use to have an e92 m3 but i sold it due to family is growing. Now I am looking for a sedan and I can't decide what to get. Maybe you guys can help me and give me some input of a M5. Thank you in advance. Last edited by BBONG; 01-07-2019 at 09:38 PM.. |
01-07-2019, 11:35 PM | #3 |
Rep 4,209
I was in the same boat before I got my car. I have a big family so I definitely needed the bigger car. Also the V8 TT can smack M3/M4 (ps I got stage two tune as well).
01-08-2019, 12:58 AM | #4 |
Rep 992
01-08-2019, 01:07 AM | #5 |
Rep 4,209
No regrets at all. It's an awesome ride. I can seat 4-5 adults no problem. Take it to Costco and load it up with a bunch of groceries. Then take it to the drag strip to put down some runs beating mostly everyone there. This is my daily car as well. I drive about 40 miles a day work and no problem whatever so. From heated steering wheel and seats to rolling down the windows for a tunnel. It's the best all around vehicle
01-08-2019, 07:34 AM | #6 | |
Rep 19,814
BBONG185.00 |
01-08-2019, 03:22 PM | #7 | |
Rep 992
Ickdeep5722.50 |
01-09-2019, 09:22 AM | #8 |
Rep 66
To some extent I am in the same boat, I am considering an F10 M5 but have toyed with the idea of the F80 M3 also.
The way I see it, without having owned either is that the F10 M5 seems to provide a bigger bang for the buck, you seem to get a lot more car/performance for the same kinda of price if not just under what it might cost to buy a used M3. Both cars would seat 5 people, but the M5 will do it in slightly more comfort I guess. Both cars have a very similar 0-60 stock sprint it seems from reading, the M5 will come into its own on motorways when the numbers start notching up. The M3 seems to provide people with a much more nimble point to point car for daily use, but the M5 isnt a slouch and people often seem to say the M5 shrinks around you as you drive it. So I guess it boils down to budget, and whether you care for extra internal room, how important low speed agility is for you (seeing as low end speeds are very comparable from what I can gather), and how shouty you want the car to look (M5 being more under the radar) For me, I am edging strongly towards the F10 M5 because like-for-like the 5 series offers more comfort/toys than an 3 series tends to, and I would expect the same applies to the Ms (eg headsup display being standard on an M5 but not on an M3 as an example?) |
01-10-2019, 09:53 AM | #9 |
Rep 224
Having had both ,the only reason I now have an M3 is that my M5 got written off, the M5 is more of a cruiser (and a bloody quick one at that) the M3 is more raw with more road noise as its not as well insulated. Used to find myself going alot faster in the M5 than I did the M3 just because it didn't feel as fast. Also the power delivery is very different with the M5 giving a brutal kick where as the M3 seems more linear. That being said I would say performance wise they are pretty close. Both stock 0-100mph wouldn't be much in it and the M5 might start to pull away after that. Tuned I'd say they would probably be similar depending on tunes of course (I've only put a CS map on mine for now, but my M5 I had a BM3 stage 2 tune on then went to stage 1 openflash) My M3 has more toys but then its a 2018 car and my M5 was 2013.. I did contemplate getting another M5 but there weren't any at dealers close to me and I saw the M3 and thought why not!
M5 was more comfortable with more space. M3 is still a nice place to be but seats are firmer and less space in the back but is alot more nimble and planted (can be partial to a bit of lift of over steer if you aren't paying attention). Exhaust wise my M5 had straight through exhaust and my M3 has secondary cat and resonator delete and I would say they are both very loud (the M5 didn't notice unless the windows were down) M3 with the valves closed is quieter at idle tho! but I still switched off cold start as it was too much. Stock the M5 is very muted in the cabin so stock for stock M3 is louder Lastly the M5 used to cost me about £80 a week in fuel the M3 is about £60 |
01-10-2019, 10:40 PM | #10 | |
Rep 992
wow thank you for taking your time to explain the different. I am deeply appreciated. |
01-11-2019, 03:49 AM | #11 | |
Rep 66
So if you had to replace your M3, and with you having owned both the F10 M5 and the F80 M3, which would you go back to again next if you were deciding between just the two? Which car just sang to you more? |
01-11-2019, 03:56 AM | #12 | |
Rep 224
I'd go F90 M5 haha and thats the main reason why I didn't go for an F10 to replace mine as I want a F90 in a few years time when they have done there first depreciation and figured the M3 would hold its value better |
01-11-2019, 09:09 AM | #13 | |
Rep 66
Also saw the new X5...another lovely car, the internal dash with that mahoooooooosive screen looks amazing. The kidney grills on the front are gigantic, borderline comically big, biggest on any model I've seen so far. |
