07-28-2020, 04:48 PM | #1 |
Rep 542
Switch oil, now zero burn?
I'm guessing the dealer I bought my M5 from used Mobil 1 0w30 or 5w30, and in the ~7k miles before I switched, I had to add a liter every ~1750 miles. I replaced with Edge 0w40 and I've supposedly burned nada at about the point I'd normally get bugged to add a liter. Have others had this experience? I was hopeful of an improvement with the heavier weight, but burning nothing is beyond what I expected.
(and hopefully the oil level sensor didn't just coincidentally go bad)
07-28-2020, 10:15 PM | #2 | |
Rep 122
Surprisingly, in my experience, the brand and additives seem to matter also. I was previously using MOTUL X-Cess 5w-40 and burned about 1 L every 700-800 miles. Yes, that's a bit on the high side, but my car probably wasn't broken-in perfectly by the past owner. MOTUL is no slouch nor is it cheap. I switched to Liquid Moly Molygen 5w-40 and currently have about 1,500 miles on the dash and burned about half a liter so far. It's the same exact weight as the MOTUL, but I seem to get about 25% of the oil burn rate. Not sure why, but it wasn't something I expected. |
07-31-2020, 06:18 AM | #3 |
Rep 606
Yes, it's definitely possible. When I bought my 2013, I had no idea what oil was in the car but it burned about the same as you, roughly 1,500 - 1,700 miles before a quart was needed. I changed the oil to Mobil 1 0w-40 and immediately had some improvement in mileage, I think around 2,000 miles. By the next couple oil changes the interval between needing quarts increased even more. Now I'm only adding a quart once between oil changes. I add 1/2 a quart at a time. I theorize the change in oil brand and weight is the reason and that it took a few changes to flush out all of the "old" brand/weight.
07-31-2020, 12:23 PM | #4 |
Rep 542
I'm now at 2400 miles since the oil change and *maybe* I've had it go dow ln one line of pixels. Or not, I don't remember exactly where it was last time.
