      07-19-2021, 05:47 PM   #67
ruben356
Drives: F13 M6 _ San Marino Blue
Originally Posted by satinof10m5 View Post
I'm using 5w-50 and my car is still doing it only on a long idle. Funny thing is it isn't that bad at all when my my throttle is in sport plus. I wonder why? Anyone have a reason for me
Same symptoms i had, when in sport plus it became excessive. Only thing for me was that when i made the switch to 5W50 it actually went away. Have you checked the pcv breathers?
      07-19-2021, 05:58 PM   #68
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Wouldn't some burn be actually good? I'm thinking that as long as you keep it topped up you have "fresher" oil. Any thoughts?
      07-20-2021, 07:20 AM   #69
ruben356
I mean for me, and as some are reporting, its a bit too excessive especially under WOT. That can be very nerve rattling for most. I know i slightly crapped my pants first time I saw huge cloud of smoke behind me, first time i ever pushed it hard.
      08-16-2021, 01:51 PM   #70
Neilb76
Drives: BMW 420d
Originally Posted by kiesha2014 View Post
You tried to change breathers?
I now have catch cans and still does it, valves see fine
      08-20-2021, 06:41 PM   #71
7sportplus
Drives: 2011 7 series 750 LI
Originally Posted by Blaxwil View Post
I thought Seafoam wasn't good for our platform due to direct injection and the turbos. ??
No issues with mine, it actually helps
      08-20-2021, 06:49 PM   #72
7sportplus
It's the DP's gentleman. If you are going to have DP's on your car then you can expect some smoke. That's Period. I put DP'S on my engine at 3500 miles, basically brand new and it smoked. Fresh oil really helps if you have DP's. That's the only thing that helps mine. I have around 10,000m on it now and no change. Sea Foam and fresh oil. Temporary fix but it works. The other alternative is to put factory converters back on.
      08-20-2021, 07:18 PM   #73
7sportplus
I agree but it's the smoke itself coming from a BMW is what bothers me
      08-23-2021, 01:18 PM   #74
ruben356
I do agree somewhat with this. Mostly any turbo that is catless smokes some. Only difference is when i first got my car it was smoking a lot, which was concerning, and as i mentioned prior. Almost 99% went away after i switched oil weight. Call it lucky i guess, as some have not had the same luck.
