      02-21-2021, 02:41 AM   #1
JonnyF10
Drives: F10 M5 2012
cylinder 5 misfire
I had drivetrain malfunction pop up yesterday just read the codes with a maxi scan tool and apparently I have cylinder 5 misfire. I was going to change all coils and plugs anyway as I’m at 70k and hasn’t been done in my ownership of 20k miles. Looking online there’s loads of different plugs and coils listed for this car. Not sure which ones to get. Can any of the U.K. guys point me in the right direction? I’m going to give this job a go myself
M5Rick60013.50
      02-21-2021, 03:24 AM   #2
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
Are you stock or tuned??? Think the plug/gap can change depending on which you are????? :
M5Rick60013.50
      02-21-2021, 03:51 AM   #3
JonnyF10
Drives: F10 M5 2012
Stock mate
      02-21-2021, 05:38 PM   #4
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Bosch ZR5TPP330- Will be perfect. I even ran them with the standard gap even though I'm stage 2 tuned. It's about that time again and I'll run the same Bosch plugs.
M5Rick60013.50
      02-22-2021, 11:59 PM   #5
JonnyF10
Drives: F10 M5 2012
Cheers il go with those what about the coils?
      02-25-2021, 03:12 PM   #6
m5rosco
Drives: 2016 F10 M5
I'm a fan of the NGK 97506 plugs, gapped to 0.022", but I am tuned.
As far as coils go it depends on year. Bosch for earlier cars, Delphi for later ones.
      02-27-2021, 04:28 AM   #7
Good luck, let us know how it progresses and what tools are needed.
      05-02-2021, 01:15 AM   #8
JonnyF10
Drives: F10 M5 2012
Guys I wanted to monitor this issue a bit longer because after clearing the fault codes the can ran fine again for a while. Then I had cylinder 5 misfire again. I reset and had cylinder 1 misfire a couple of times and now cylinder 6 a couple of times. Only under high load. And now I can’t reset at all. Not had any smoke or anything and the car will still run in limp mode as I had to get home from work but with no power obviously. Should I still change all the plugs and coils??
      05-02-2021, 05:26 AM   #9
robbiep
Drives: VW e-Golf !
I'd get a proper diagnostic carried out by a competent garage (not necessarily a BMW dealer, plenty of very good indie specialists out there), rather than a basic cheapo scan like you're using and then clearing the fault codes and hoping they don't come back
      05-02-2021, 05:28 AM   #10
m5rosco
Drives: 2016 F10 M5
If they haven’t been done in a while I’d definitely change plugs and coils.
J11SEK268.00
      05-03-2021, 01:33 PM   #11
J11SEK
J11SEK's Avatar
Drives: F10 M5 2015
Yes change them!! As you've said earlier they've been in for 20k plus miles..... definitely need them changing regardless of the fault
M5Rick60013.50
      05-07-2021, 06:45 AM   #12
If it hasn't been said always clean the MAF's first before starting on anything else, mine's on 38k,plugs never been changed and running like a train. Doing them at 40k.
J11SEK268.00
      06-21-2021, 02:51 PM   #13
JonnyF10
Drives: F10 M5 2012
Bit of an update chaps I changed all the plugs and coils reset all the codes and just have cylinder six injector codes now and the car is still in limp mode. I have bought 8 new injectors and im letting my indy (darren woods) do the work. Its twenty miles away takes about 25mins, would it be ok to drive there in limp mode. Warnings are in yellow not red?
      06-22-2021, 02:26 PM   #14
m5rosco
Drives: 2016 F10 M5
Personally I wouldn't, but then my best mate has got a recovery business (we're a bit far away from you though!)
      06-22-2021, 05:52 PM   #15
Probably not a good idea to drive it there.
      06-22-2021, 05:58 PM   #16
JonnyF10
Drives: F10 M5 2012
Yea I thought the same I have recovery taking me there tomorrow, cheers
      07-13-2021, 05:47 PM   #17
JonnyF10
Drives: F10 M5 2012
So I had all 8 injectors replaced. Still a misfire. Had a compression test. All good thank god. So I’ve been told the failed injector sent a spike back to the ecu and fried something in there. Both ECU checked and one of them is being repaired!
      07-14-2021, 05:44 AM   #18
JLR1969
Drives: Kubota GR1600
Bloody M5s great when they work and so expensive when they dont. I guess at the end of the day its a £100K car thats available for £25K
      04-07-2022, 03:27 PM   #19
BlackBear
Drives: M6 Cab + M850 + McLaren 570Spi
Hi Jonny,
I have the same issue. Replaced all coils, plugs, and one injector (coded it) and still have misfires on all cylinders in bank 1.
What was repaired on your DME/ECU? Was it the MOSFETS?
Thank you.
      04-13-2022, 02:01 AM   #20
JonnyF10
Drives: F10 M5 2012
Hi I don't know what was repaired inside the ECU I was just told the bad injector sent a spike back to one of the ECU's and damaged something inside. The one bad ECU was removed and sent to specialist, repaired and refit and the car has been faultless since.
M5Rick60013.50
