05-31-2022, 10:42 AM | #1 | |
Rep 3,690
F1 2022: Azerbaijan GP - Baku (June 12)
2021 GP highlights: |
05-31-2022, 09:16 PM | #3 |
Rep 4,660
05-31-2022, 11:37 PM | #4 |
#buildnotbought
10855
Rep 4,893
I think this will be a RB track. Also with how strong and durable the RB engine block seems to be (Max is still on this first engine)
It will be interesting to see how MERC will be performing. They have a fast car (with that I mean top speed), very important with the long straigths but is porpoising really gone and can their very stiff suspension that they seem to have to run handle a street circuit with such high speeds? My prediction: 1. VER 2. PER 3. RUS 4. LEC 5. HAM 6. SAI 7. NOR 8. BOT 9. OCO 10. KMAG Baku is an awesome track through a beautiful city. Some parts remind me a bit of Paris.
06-01-2022, 09:13 AM | #5 |
Rep 3,690
06-02-2022, 04:46 PM | #7 | |
Rep 19,543
06-02-2022, 08:14 PM | #8 |
#buildnotbought
10855
Rep 4,893
Bad day for Ferrari then
My guess is that they're going to give Max a new engine and give it a very aggressive tune (because he still is on his first engine/turbo/etc), so I expect his car to be very fast.
06-02-2022, 10:13 PM | #9 |
Rep 10,663
Always a great track, and probably my favorite to drive on in the F1 games!
NYG10741.00 ///M Power-Belgium63359.50 |
06-03-2022, 02:41 AM | #10 | |
Rep 7,429
I don't think the merc has a top speed advantage, I think it is competitive now but not ahead everyone else. In terms of porpoising street tracks don't help, and some guys on f1tech have speculated/heard it was due to limited suspension travel rather than running too stiff. So they kind of don't have the dampening they would want.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
NYG10741.00 |
06-03-2022, 02:56 AM | #11 | |
#buildnotbought
10855
Rep 4,893
I have a hard time believing that that would be the problem. I mean, they've been racing in monaco for over 90(!) years, so they know exactly how bumpy it is. Designing suspension with too little travel would be an epic fail. If that is the case, they will certainly have the same problem in Baku. Unless of course it isn't limited suspension travel, but just too little ride height... I mean suspension travel is dependant on the ride heigth, otherwise your floor is constantly bottoming out, resulting in disquaification. But why too little ride height? not enough downforce from the new floor? Design flaw to solve the propoising?
06-03-2022, 03:18 AM | #12 |
Rep 19,543
This is what I'm thinking ,a new second PU for Max would spread out the wear rate. As far as aggressive tune I would be wary of the tyre deg with thoughts of last years blow outs.
06-03-2022, 03:22 AM | #13 | |
Rep 7,429
It is ground effects era you have to try and run as low as possible to get downforce, which drops off exponentially with ride height. It isn't really dependent on how much downforce the floor makes, rather how well the floor is sealed. Because an overall high downforce producing floor can make less downforce vs. an overall low downforce producing floor at the same increased ride height if it is sealed worse. This is why I believe mclaren did pretty well in monaco, because it is known their floor is sealed very well with the immesenly powerful vortices that run along the floor, so despite them likely making less downforce vs. the top teams, the ride height increase for the street circuit dropped all the top teams down to mclarens level (who with the better sealing were able to lose less downforce). The sealing effect is probably exemplified at low speed because the air traveling over and under the floor is slower so the voritices produced are weaker. This means if a team has really weak sealing vorticies the seal gets even weaker at low speeds, further benefitting cars with better sealing. So in essence it is the combination of sealing and ride height increase that really hurts teams in terms of downforce not just ride height.
06-03-2022, 05:39 AM | #14 |
Rep 1,794
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Pleased that RBR formally stated they won’t block Perez’ fight for the title…and did it quickly after asshole Jos Verstappen’s crying and criticizing comments about the Monaco GP results.
https://www.gptours.com/gr_news/red-...rez-title-bid/ |
minn1914034.50 |
06-03-2022, 05:43 AM | #15 |
Rep 19,543
^Couldn't see you saying the same to support BOT when he and HAM were fighting for the title in Merc..
06-03-2022, 06:24 AM | #16 |
Rep 1,794
Drives: E86 3.0si
Think you missed what I was pleased about...RBR formally stating that both drivers have their right (and RBR's permission) to fight for the championship. I could be wrong, but I don't recall Mercedes Benz expressing that.
06-03-2022, 06:42 AM | #17 | |
Rep 7,429
Merc never stopped Bottas or Rosberg from fighting for the win until it was near impossible for the other driver to feasibly win given that the other team driver was also in the mix. So this means if it's a 3 way fight for the battle: 2 Merc drivers + another team, there will be no team orders if the 2 Merc drivers are close. If 1 of the 2 drivers is really far behind and not capable of a guaranteeing a win every weekend then they will be forced to help the lead driver in a tight championship. This is why Bottas always was given a chance at the start of the season but he always fell off later on so he had to help Lewis. Merc also let Bottas have wins back when he was forced to give Lewis position to prevent others from getting into his pit window. So to be fair redbull still owes check one.
minn1914034.50 |
06-03-2022, 08:29 AM | #18 |
Rep 238
Almost every team says they don't have a number 1 driver but race strategy indicates otherwise.
When they use a more aggressive strategy for one driver over the other such as under cutting. Very few times is pit strategy the same for both cars. |
06-03-2022, 09:24 AM | #19 |
Rep 24,668
You nailed it completely
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-03-2022, 09:26 AM | #20 | |
Rep 3,690
06-03-2022, 09:40 AM | #21 |
Rep 19,543
You are right Merc didn't say that and is why the general thought was that HAM would have the advantage.
06-03-2022, 10:45 AM | #22 |
Rep 1,794
Drives: E86 3.0si
Mercedes Benz isn't the first team to favor one driver. I should add that I care little about them and their reasons. It's obvious that MB's way bothers you but as a Red Bull fan you should also be pleased that Marko and Christian plainly state their first concern is winning the manufacturers championship.
minn1914034.50 |
