02-04-2022, 09:10 AM | #1 |
Rep 2,064
First 2022 Regulations F1 car revealed
The Haas VF-22. Looking damn good if you ask me!
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
3798j11636.50 overcoil3081.00 Killed by Death13120.50 ///M Power-Belgium64681.50 GuidoK11104.00 M5Rick61740.00 |
02-04-2022, 09:39 AM | #2 |
Rep 1,825
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Looks sweet.
A good time to look at this...Seven key rule changes for '22: https://www.formula1.com/en/latest/a...xxw6r5yDS.html |
Killed by Death13120.50 |
02-04-2022, 11:06 AM | #3 |
Rep 1,825
Drives: E86 3.0si
Here's an analysis of the new Haas. A bit lengthy, but interesting to see the changes in not only the car, but also the organization...car was designed in house rather than relying on Dallara.
EdM54075.00 Killed by Death13120.50 |
02-04-2022, 12:03 PM | #4 | |
Rep 3,654
Didn't Ferrari learn that lesson long ago Hope Haas is just playing games to hide the real setup |
///M Power-Belgium64681.50 M5Rick61740.00 |
02-04-2022, 03:46 PM | #6 |
Rep 3,654
02-04-2022, 04:14 PM | #7 |
Rep 1,825
Drives: E86 3.0si
Their reasoning...
"Scuderia Ferrari is confident in its decision to use Pull-Rod configuration on the 2022 front suspensions – in total contrast with the push rod suspension geometry seen on the latest cars. This call made by the Italian side is manily dictated by aerodynamics: the Pull-Rod configuration allows the flow to be redirected towards the bottom of the car and straight into the cooling inlets, which should also be lower, all matched by a more compact rear end thanks to the cooling “gills” allowed by the new regulations." https://scuderiafans.com/2022-ferrar...ension-system/ |
02-04-2022, 04:54 PM | #8 | |
Rep 3,654
What did last years cars use? Push-Rod? If so that's what they should stick with. So Ferrari is going to try Pull-Rod configuration again? The drivers hated it last time many years ago. Don't understand why Ferrari would go down that road again. Aero benefits aren't worth sacrificing driver feel IMHO. Last edited by Killed by Death; 02-04-2022 at 05:50 PM.. |
02-05-2022, 11:24 AM | #9 |
Rep 1,825
Drives: E86 3.0si
Will the new formula make the cars harder to drive? Remembering the last ground effects era, it seemed to make average drivers super. Here's driver61's video explaining (among a lot of other things) how this new era of ground effects differs,
02-05-2022, 01:36 PM | #10 |
Rep 24,942
Exactly.. It looks too 'cheap !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick61740.00 Killed by Death13120.50 |
02-05-2022, 02:11 PM | #11 |
Rep 19,949
///M Power-Belgium64681.50 |
02-05-2022, 04:04 PM | #13 |
Rep 19,949
02-09-2022, 06:37 AM | #15 |
#buildnotbought
11104
Rep 4,930
Today at 5pm (I assume CET) the new 2022 Red Bull car will be revealed (RB18)
02-09-2022, 09:48 AM | #16 | |
Rep 24,942
So...Let's say they show today the RB18 color scheme . Let us hide it for the #MercedesCopyCat ! EDIT ....
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 02-09-2022 at 10:10 AM.. |
Killed by Death13120.50 M5Rick61740.00 |
02-09-2022, 02:11 PM | #17 |
Rep 1,825
Drives: E86 3.0si
"Red Bull have launched their 2022 Formula 1 campaign today with what appeared to be a showcar." Looks low and sleek...like a ground effects car should. I too am not a fan of the cheap looking wheel discs.
02-09-2022, 02:19 PM | #18 |
Rep 1,819
It’s the model or a copy of the show car nothing more or less it has NO resemblance to their real car only the livery will be similar.
HAAS at least showed a tiny bit of what their car might look like Redbull is having a laugh, shame really should be called a livery launch not a car launch. |
02-09-2022, 02:27 PM | #19 |
Rep 1,008
Why those wheels? Because...
02-09-2022, 02:31 PM | #20 | |
Rep 3,654
Still hoping Ferrari go back to gloss |
02-09-2022, 02:31 PM | #21 |
Rep 1,825
Drives: E86 3.0si
Here's a review of the RB18 "showcar"....
02-09-2022, 02:31 PM | #22 |
Rep 1,819
They are standard spec for ALL teams, you won’t find any different in any team.
Believe it or not they have tested adding LEDs to the covers in testing. Might be used for advertising or to show position, if they have pitted potentially. Not confirmed to be used yet but it’s being looked at. |
Lady Jane72100.50 |
