      03-09-2020, 11:47 AM   #1
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
16 F10 M5: Mirror Folding...am I blind?
Bimmercode: Purchased Full.
Seems as if this function should work when using comfort lock on door handle per the attached..but negative. Also, in basic mode, dont seem to be able to enable the folding mirrors via fob?
I also noticed that when I increased my angle eyes to 100%, now my interior ambient lighting is now more whitish vs the orange/red color? Which is ok..but where might is color setting be if in the event I want to change back?
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      03-09-2020, 01:16 PM   #2
Dwaynos
Dwaynos's Avatar
Mirror fold only occurs when you hold the lock button or hold on the handle. I'm sure somewhere in expert mode you'll be able to code to fold on single press. Never bothered me, I just use the button inside.
      03-09-2020, 01:37 PM   #3
Fast.F10
Extruding Elements
Fast.F10's Avatar
Just tried: holding the remote lock doesnt fold the mirrors but keeping hand on handle for a few seconds does. Disarming either way, folds the mirrors back down. Rather them fold via the FOB. Will have a look around and in expert mode.
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      03-10-2020, 12:22 PM   #4
texsn95
Drives: 2014 Frozen Silver M5
There are 2 more options located in the CAS (I think that is the FEM in Bimmercode) that you need to change, without having to go into expert mode. From the cheat sheet. I clearly remember having to do all 3 and then changed the delay. I'm at work so I can only look at Demo right now.
- Enable key fob and driver side door handle to fold mirrors* and close windows and moon roof
CAS => 3003 => KOMFORTSCHLIESSUNG_FB => aktiv
CAS => 3003 => KOMFORTSCHLIESSUNG_PA => aktiv
FRM => 3020 => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN => aktiv
* To change mirror fold delay
CAS -> 3003 -> KMFRT_SCHLIESSEN => Werte= 05 for 0.5 sec, 0A for 1 sec, 0F for 1.5 sec
1995 Mustang Cobra - 347 stroker
      03-11-2020, 08:37 AM   #5
Fast.F10
Extruding Elements
Fast.F10's Avatar
Hrmmm, demo mode not connected seems a bit different than demo mode connected. Here is demo not connected. Will take a screen of same module in demo once connected in a few hours.
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      03-11-2020, 02:29 PM   #6
TLK
TLK's Avatar
112
My recollection is that you have to set the delay low to get it to work. Search the web for f10 coding cheet sheets. You probably have to look up the info yourself, and not rely on bimmercode's canned stuff.
