      12-12-2014, 02:19 AM   #1
justinluv949
Drives: 2015 M5 GRAY ON RED
Installing a subwoofer, help,
I want to add a subwoofers to a new 2015 M5.
My M5 has the regular HK stereo system.
In the I drive it has the equalizer.
I have 1 Zapco 1100.1 and 2 Image dynamics IDMAX sub woofers.
The Zapco amp is older and it's not the new Digital amplifier.
It uses a SymbiLink Cable. It plugs into the amp, and the other end has 4 wires on it for a 2 channel signal that would tap into the cars low audio sub signal.
Normally I would just tap into a low signal of the car, and run the subs off of it.
My question is where are the wires located to tap in and Where is a remote wire located.
Is there a better way to do this, or does someone make a harness that is just plug-and-play?
Do I need a line driver? Like an audiocontrol.
Thank you for your help.
      12-13-2014, 01:10 AM   #2
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
PM Technic. He is the resident audio guru and seller of wiring harnesses you will need.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
      12-13-2014, 02:47 AM   #3
justinluv949
Finally a response, LOL
Ok thanks,
      03-28-2015, 09:15 PM   #4
Antônio Júnior
Antônio Júnior's Avatar
Brazil
Drives: Volkswagen
BMW M5 2015 with Bang & Olufsen
BMW M5 2015 with Bang & Olufsen...
Is possible install a subwoofer (10") in the car trunk?
If possible, as is control of subwoofer? Is independent of original system?
