      10-09-2018, 02:38 PM   #1
robotfixr
Drives: 2015 M5
Starting in 2nd gear
I did a search but not could not find this issue. Pardon me if this is duplicated.
2015 M5 DCT. Sometimes from a dead stop it will shift back down into 1st and most of the time just to 2nd. Major pain as the car struggles to take off often slipping 2nd gear clutch for extended period. This can't be good for the clutch. Any idea what is going on here? Is it just a simple software update? Car was just in for service about 3 weeks ago.
      10-09-2018, 03:49 PM   #2
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
What tension is your transmission set at? Second gear start on flat ground can be normal if in D1 even D2.
      10-09-2018, 04:25 PM   #3
robotfixr
Drives: 2015 M5
It does it in both. So if a flat surface is the determining factor?
      10-20-2018, 11:51 AM   #4
internetryan
internetryan's Avatar
Drives: 2014 M5
I'm pretty sure I've noticed this in the comfort setting. I think it's just a way to make sure the start rolls very smoothly in certain situations. You can also choose to start in second gear from a stop if you want to manually. This is especially good for starting on snowy roads.
      10-20-2018, 06:43 PM   #5
boots
Curve Thrasher
boots's Avatar
623
all of ours does that. just move your selector twice to the right and your in 1st auto. once for stick shift
Country run
      10-24-2018, 07:45 AM   #6
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
In D3 should always move to 1st gear. However, starting in second isn't abnormal. If your clutches are slipping then that's a different story.....
      11-06-2018, 08:30 PM   #7
TLK
TLK's Avatar
112
Unfortunately this is all too normal. This why I don't use the D modes. Even in S3 you have to either come to basically a dead stop before it will drop to 1, so most of the time I have to click the paddle one or more times to convince the DCT to drop to 1.
      11-06-2018, 10:41 PM   #8
Craze
In australia our cars always start in gear 1
      11-07-2018, 05:14 AM   #9
PattyF10M5
Drives: MCB F10 M5
Mine starts in 2nd regularly and I am from Australia.
      11-07-2018, 11:49 AM   #10
Dwaynos
Dwaynos's Avatar
I noticed mine starts in 2nd if I come to a gentle stop. Stop slightly more abruptly and it starts in 1st.
      11-08-2018, 03:34 AM   #11
Craze
Hmmm mine never does lol
      11-23-2018, 05:15 PM   #12
Traffic crawling stopping in 2nd then stopping from normal drive !st.
      11-30-2018, 07:30 AM   #13
EnderG60
Drives: 2014 M5 / 2012 M3
Mine starts in 2nd all the time in comfort mode, so I stopped using it. Drives much better in M1.
It also doesnt like to downshift to first when I go up my steep ass driveway so I usually have to downshift to get it to actually make progress up the damn hill. That drives me nuts.
      11-30-2018, 09:54 AM   #14
core22
core22's Avatar
140
Drives: X3 M40i / 911 C4S
Mine never starts in 2nd, whether in auto or manual mode, and 1, 2, or 3 makes no difference. Like this on my LCI, as well as my former 2013. Most days I would love to start in 2nd all the time as long as there was no slippage as mentioned by the OP.
Current:
2019 911 targa 4 | GT Silver Metallic
2019 X3 M40i | Glacier Silver
Past:
2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi
      12-08-2018, 07:26 AM   #15
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
When its starts first time in 2gear just tap litle gaspedal and it change 1st gear and newer start 2 gear in this driveing. But when you turn off engine. And start engine again when start 2 gear you have to do this again. But just litle tap accelerator pedal and change 1st gear.
      12-13-2018, 04:53 AM   #16
PattyF10M5
Drives: MCB F10 M5
This worked! Thanks for the info.
The F10 M5 is a mysterious beast full of secrets and surprises.
      12-14-2018, 04:58 PM   #17
finlandm5f10
yes it works.
      01-11-2019, 02:13 PM   #18
robotfixr
Drives: 2015 M5
Lot of good feedback here. It can be a pain as unless I am watching the shift indicator I am not sure what gear it is in. Then we I try to sprint and it starts in 2nd it is slow. The double gear move to right does work. However, since I drive it about every day I don't want to paddle shift all the time. I guess I just suck it up and drive it like I stole it.
      01-19-2019, 05:56 PM   #19
finlandm5f10
You should reset gearbox learn setup. That fix the problem.
      02-11-2019, 11:25 AM   #20
robotfixr
Drives: 2015 M5
How do I do this?
      02-11-2019, 09:04 PM   #21
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Originally Posted by robotfixr View Post
How do I do this?
Dealer or tuner can re adapt the clutches for you. Takes about 15 min, transmission has to be up to temp.
