12-01-2018, 11:11 PM | #1 |
Rep 43
Molygen New Generation 5W-40 in Australia?
Does anyone from Australia use this oil and can get it at a decent price, if so where?
Liqui Moly doesnt supply Molygen to Australia and likely wont so the only option I can see is to buy online. The shipping and tax costs are over $100 alone making this a rip off. Anyone in the same boat find a reasonable solution? Thank you, |
12-03-2018, 05:50 PM | #2 |
Rep 142
Molygen
G’day Patty
It appears this Oil is Synthetic Based not Full Synthetic. I note you have raised oil burn in another part of this forum . I only use Full Synthetic Oil and our engines need this sort of protection . Have a look at the Audi Forum discussion board with regard to this oil : https://www.audizine.com/forum/showt...-Molygen-5w-40 Cheers Bruce |
12-05-2018, 07:57 AM | #4 | |
Rep 43
12-05-2018, 07:50 PM | #5 |
Rep 142
Molygen
G’day Patty
Interesting (and happy to be corrected) because the product data sheet does not say this : https://pim.liqui-moly.de/pidoc/P001...40-31.0-en.pdf Liqui-Moly make fine products but it’s not available in Australia. Our engines generate lots of heat because of the “hot vee” design and I use Mobil 1 0W-40 because of the high TBN (Total Base Number) . It holds approvals for Porsche/Mercedes AMG/Bmw . I have used this oil on all of my turbocharged engines since 2010 with great success . Most important is that this oil flows very well when cold and hot ; and thus protects the engine (hence the 0w and 40w part of the oil viscosity). Ps : have you checked the recall status on your car from Bmw Australia: #1 :Cooling Protector Mats for the Turbocharger Cooling Lines #2 : Drivers TAKATA Airbag All of this is covered by BMW Australia Cheers Bruce |
12-06-2018, 06:44 AM | #6 |
Rep 43
I thought you might say Mobil 1 0W-40. I think ill be using that too.
I have checked air bags and all good but not sure about the Turbocharger Cooling Lines defect. It was purchased from West Cost BMW where I service it so would think that all would have been checked but I will follow up. |
12-15-2018, 03:38 AM | #7 |
Rep 99
Ill be doing an Oil change soon using Ligui Moly Molygen, hopefully can give a feedback soon.
Individual Amazonite Silver| B&O | KW V3 |Forgeline GA1R-Centerlocks | Forgeline Centerlock Conversion |K&N/Charcoal delete | AFE CF Scoops | RW Carbon Lip | IND-Style Front/Rear Markers | IND-Style Black side Grille/Rear M5 Emblem | LCI Front Grille | Dinan Sway bar | Powder Coated Cocaine White Calipers | ECS tuning Brake lines| Carbothech - Akebon0 | M-Performance CF Rear Center Diffuser | RPI GTM Exhaust | Suntek PPF |
12-16-2018, 03:08 AM | #8 | |
Rep 43
I did my first oil change on the m5 over the weekend. Used some mobile 04w-40 and car felt good. It cost about $100 Australian which is slightly less then some molygen delivered to Aus from ECS tuning so it still might be worth it. |
