      09-04-2018, 03:17 AM   #1
Vancouver_M440
Vancouver_M440's Avatar
Drives: 2012 M5 Sedan
Bimmercode Help with Trunk Close and AC
There's been a few things I wanted to change using Bimmercode and i can't seem to get it work.
1. Trunk close via remote or the trunk open button - looks straight forward enough as it's not even a thing you need to use Expert mode for but it fails reading the ECU data from the module. Anyone else experience this and found a work around? Mine gets to about 90% read and then errors out
2. Keep AC off when I start the car - I toggled the AC off options but my AC still turns on everytime I start the car. Is there something else that needs to done here?
3. Turn off easy entry so the steering wheels doesn't go up and down everytime I start and stop the engine - Not sure if this needs to be coded but I can't find a way to do it in the iDrive
      09-04-2018, 10:43 AM   #2
PRKELLY
Drives: 14 M5 CP
For the trunk,. try enabling slow data rate. I think thats what its called.
Not sure on AC, mine worked fine when I coded it.
The steering wheel will need coding, I do not thin thats an iDrive option.
      09-16-2018, 05:08 PM   #3
SapphireM5
SapphireM5's Avatar
711
Here is the cheat sheet I used:
https://f10.m5post.com/forums/showthread.php?t=907307
