08-16-2018, 01:57 PM | #1 |
4496
Rep 1,862
Drives: powered by bootmod3
*** Boost/Torque by Gear (% Reduction) - New Map Configuration option - bootmod3 ***
Hey guys, this one's been in the works for some time and we're happy to release it with the 0.10.029 system update.
Many of you can attest to being very hard to effectively put down power even with a Stage 1 OTS map even after going with great tires and setting up suspension and alignment right. We've come up with a simple and easy to use way to help you reduce boost (torque) for any given gear so you can better put it down. 1st and 2nd gear are most often the ones that need some help but we've exposed gears 1-6 for it. Some may even use it to create a low boost map using it as a simple boost tuner Update is up on bootmod3.net and the Android app store has the update. iOS version is in review as usual and hopefully live in the App Store in the next 24-72hrs. Let us know if any questions at all
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
08-16-2018, 06:00 PM | #2 |
Rep 673
Awesome! Thank you so much for this feature. Is the 1st gear and 2nd gear reduction 60% and 40% the default and the best option for drag and rolll racing so from 40-60mph. Sorry hope my question made sense.
08-16-2018, 07:04 PM | #3 |
Rep 420
Has the OTS Stage 2 comes is there any sort of boost reduction involved alread in 2nd gear? Just wondering if I can turn the reduction down aslong as I have a setup to put the power down will it dig harder in 2nd then before?
08-17-2018, 04:01 AM | #4 |
Rep 1,847
With less boost it should produce less power so traction should be improved
08-17-2018, 11:29 AM | #6 | ||
4496
Rep 1,862
08-17-2018, 02:48 PM | #7 |
Rep 2,349
So let’s say stock is around 20psi and you set it to 60% in first, with a max overall boost of 24psi.
What is your boost in first? 20psi because it can’t go below stock, 60% of 24psi or 60% of 20psi? |
08-19-2018, 09:18 AM | #9 |
Rep 232
Tags |
bm3, boost by gear, bootmod3 |
