10-06-2017, 08:15 AM | #1 |
Rep 352
Drives: 2003 E39 M5 + 2013 F10 M5
Catless Downpipes - With and Without Tune
So here are two questions. My Stock F10 M5 with just carbon filter delete and OEM downpipes roughly yields 509WHP and about 500WTQ after taking to dyno.
1) If you then add downpipes (catless) with no tune and leave it as it, should it make a difference in WHP? I feel turbo spool in 2nd and 3rd Gear (low end) is faster and more responsive, without a doubt (or maybe its just that intoxicating sound of the turbo whistling and downshift cracking ). But ON a dyno - should this thing yield more WHP than stock? 2) If I have a stage two flash (this was when I had OEM downpipes), should tuning company tweak this flash to account for Catless Downpipes now? What I mean is, does a flash tune take into account the fact that the car has Catless DP, and as a result yield even more power? Everyone says Catless DP should probably increase your WHP by 20-35whp but I am assuming this is via tune, or should that happen naturally without tune? thanks |
10-06-2017, 12:30 PM | #3 |
Rep 352
Thanks Trevor. I only did one pull with catless downpipes, and it yielded 511 WHP (2 whp above 509WHP. Granted I did not even let the car cool down before using it in 95 degree weather and humidity at 99% lol.
So WHP did not vary with just Catless DP and NO TUNE. |
10-07-2017, 09:53 AM | #4 | |
Rep 2,039
To me, catless is more for sound (a glorious sound, undoubtedly) and a supporting mod for for turbos operating at max output. |
10-07-2017, 09:55 AM | #5 | ||
Rep 352
10-07-2017, 02:29 PM | #7 |
Rep 553
I just don't like the CEL with catless DP as stock the power is plenty. The car can barely get traction 1-3.
I am getting a CEL with my bms intakes too but the sound is just so intoxicating. Do you guys think the downpipe help the turbo since they flow better? On my old 335s I always do the downpipes since they say it helps the turbo. Can this be considered a "reliability" mod for the s63tu turbos too you know....trying to justify buying them. |
10-07-2017, 02:49 PM | #8 | |
Rep 352
10-07-2017, 02:52 PM | #9 | |
Rep 553
I just dont bother with tune because always you have some sort of problems. I am going to change my plugs and coils anyway but with tunes then misfires start that is not for me...I already played that game with the n54. Btw do u hear the waste gates rattle more ? |
10-07-2017, 02:59 PM | #10 | |
Rep 352
Get some headphones or speakers with bass and play this quick video. This was simply recorded with my iphone, and you can still hear the spooling whistle. It is much louder in person. |
M5_Brandoe237.50 |
10-08-2017, 12:41 AM | #11 |
3387
Rep 7,541
Will definitely have an increase - but the increase is greater when tuned.
A tuned car with stock DPs will destroy a stock car with Catless DPs. Basically the DPs are a complimentary modification to the tune. Think of the engine as an air pump, air goes in and out. With stock software, you’re pushing less air - so the restriction on the back side is less than it would be if you were forcing more air in.
11-13-2018, 04:58 AM | #12 |
Drift Instructor @ BMW Club UAE
310
Rep 433
Drives: BMW F10 M5
Reviving an old thread I guess...
I just got catless DPs on my F10 M5 (VRSF DPs) and I felt the power increase when the car adapted to the DPs. I can safely say the car gained 30 WHP with stock tune and stock everything else. It is my first mod at the moment. As everyone else said, the spool sound, pops and the burble are intoxicating!
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current) Follow me on Instagram (Click) |
11-13-2018, 11:59 AM | #14 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The difference between a proper tune on a stock car and a proper tune on a car with catless downpipes is minimal. Our stg1 tune alone get you 630-650whp on 93oct. Adding down pipes and a tune that defeats emissions diagnostics won’t get you much more than noxious stink and a lot more noise.
Cheers Shiv |
11-13-2018, 12:43 PM | #15 | |
Rep 2,039
11-13-2018, 01:27 PM | #16 |
1736
Rep 17,960
Drives: A Lot
11-13-2018, 07:23 PM | #18 |
1736
Rep 17,960
Drives: A Lot
653whp with only a 93oct tune (no other mods): https://f10.m5post.com/forums/showthread.php?t=1554578
The only real advantage of running cat-less downpipes is for racing applications where you can disable all the ECU's catalyst protection strategies that would otherwise drop boost and enrich AFR when calculated catalyst temps get high (ie, sustained top speed runs or hot lapping at the track). But for 99% of us, this doesn't apply. On the street, the s63tu can make as much peak power as you can reasonably want with stock DPs. Catless DPs, in other smaller displacement platforms, can be useful since they speed up turbo response time and improve low end/midrange torque. But in the case of the s63tu, boost response is already excellent and most competent tuners will already be limiting low end/midrange torque anyway to preserve transmission/engine integrity. So I fail to see where running cat-less downpipes provide any real advantage for most of us. But if you like the extra noise, expense, stink and the thrill of breaking the law and polluting the air we breathe, who am I to say otherwise? I'm just trying to provide realistic expectations as to what to expect in terms of actual performance gains. Cheers Shiv |
11-14-2018, 12:05 AM | #19 |
310
Rep 433
Drives: BMW F10 M5
Don't mean to hijack the thread but to give you more info on this topic. Here are my Dyno Charts for my car (DP with stock tune)
https://f10.m5post.com/forums/showthread.php?t=1555049
11-14-2018, 09:50 AM | #20 | |
Rep 2,039
Do dp's give a ton of power? No. Do they contribute to the longevity of the turbos? Most likely. Does the turbo whistle sound cool? Definitely. If you're concerned about the environment make sure to call out those polluters at the next car meet. When you were at Burger Tuning** no one ever criticised the polluters and promoted the CEL bypass capability like there was no tomorrow. After you left and set up shop in CA and BMS was fined, all of a sudden "dp's are a waste of time and money." Just look at the tone over at n54 tech. **Correct me if you weren't at BMS, I will retract my comment about that. |
11-14-2018, 10:20 AM | #21 | |
1736
Rep 17,960
Drives: A Lot
06-26-2020, 04:37 AM | #22 | |
Rep 1
Did you get a check engine light on with the catless downpipes? |
