      07-10-2019, 01:06 AM   #1
mattkerby1
Drives: M5 F10 2014
M5 F10 Front Brakes
Hi All,
Following a lot of threads on OEM brakes v's aftermarket I went about to try and solve the problem and share my results which turned out to be more cost effective than buying OEM - and when the rotors wear, an even cheaper replacement.
This set up has been design by myself and currently over 2000 miles in with superb results. My set up consists of
1. Pair of 410x36mm (hook) rotors.
2. Floating aluminium bells, hard anodised black
3. AP racing 1/4" bolt fitting (bobbing) kit
4. 7mm Aluminium spacers for caliper offset
5. Pads machined to suit 122mm Radius (bell clearance)
Must say really really happy with it and how it turned out, combined with the braided hoses and racing fluid is an amazing upgrade. Only down side is with floating discs - even with this sprung loaded bobbing kit can be a little noisy with the 'hook' design in the rotors. Do not get any squeal what so ever from the EBC yellow stuff pads which I am testing with this setup.
Off to the 'ring' in 2 weeks and feeling a lot more confident on the brake performance.
OneExtra809.50
      07-10-2019, 08:02 AM   #2
OneExtra
OneExtra's Avatar
Drives: None
Look good, how much did it all cost?
      07-10-2019, 10:42 AM   #3
mattkerby1
Drives: M5 F10 2014
In total I spent just under £1,000, but that was including the designing time (CAD) and machining of the pads on my CNC machine.
OneExtra809.50
      07-23-2019, 05:47 AM   #4
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Drives: BMW F13 M6 CP GT3
Originally Posted by mattkerby1 View Post
Hi All,
Good job! Sent you a PM
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
      07-29-2019, 04:51 AM   #5
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Hi All,
Hi Matt,
I sent you more PM's.
      07-30-2019, 02:32 AM   #6
mattkerby1
Drives: M5 F10 2014
Sorry away on holiday at the moment will be back next week to reply.
Apologies for the delay guys.
      08-21-2019, 10:37 AM   #7
b21playa
Drives: LCI e60 535d msport
Would have been interested but just brought discs/pads all round from the dealer
      08-25-2019, 01:45 PM   #8
Pitch_M5
Drives: Bmw M5 F10
Those brakes look quality
      08-25-2019, 08:45 PM   #9
Blaxwil
Blaxwil's Avatar
620
Drives: 2015 M5
Hi All,
I would suggest using the money you saved to purchase a set of jack stands. Using your wheel isn't ideal should something go bad. I'm jus saying
