07-27-2024, 05:43 PM | #1 |
Rep 10
Help needed with rear axle diff noise
Hello,
I have a metallic clunking noise from the car while driving which I do not understand where it is coming from. I bought the car with a broken rear diff mount and intermediate axle, replaced the parts and the car has been fine. For information, the mount was used, but with low km. Got a bad clunk sound a while ago from the rear, slack in both cv shafts. Replaced both shafts, probably 50km on them now. But there's still a sound behind it that I don't understand what's coming from. - The sound comes when starting from a standstill, it doesn't matter if you turn to the right or left. - It also comes when driving on speed dumps or some uneven road sometimes - The sound is also there when I put it in manual mode and release the gas, then I give a little gas and it is there I can't imagine that there should be something inside the diff, because then there should have been noises constantly and not just on a few occasions. Could it be that there are bad diff mounts, will it make such a sound? I am attaching a link to my YouTube channel where I have uploaded videos of the sound. Username on account is M5F10M5 - M5 F10 rear axle noise Appreciate all help and suggestions. www.youtube.com/@M5F10M5 |
08-01-2024, 06:52 PM | #3 |
Rep 577
Could be a cracked diff mount that flexes as you put power into it and drive away. I would drive very carefully until its resolved.
08-02-2024, 04:37 AM | #4 | |
Rep 266
4-door sedan/saloon (F10) 5-door estate/wagon (F11, marketed as "Touring") His signature says F11. |
M5Rick66675.00 |
08-02-2024, 05:10 AM | #5 |
Rep 21,553
I know but the vids that relate to the problem are of an F10 saloon that looks like a Competition with those 601M wheels and the Comp's have a different rear axle ratio to standard M5's which is why I'm asking him if it is one.
KurtsM5233.50 |
08-03-2024, 04:19 PM | #9 |
Rep 21,553
08-04-2024, 08:15 PM | #11 |
Rep 10
The diff mount and driveshaft was broken and was changed, my wife has been driven the car since then to work and home. No pulls at all.
08-04-2024, 08:18 PM | #12 |
Rep 10
Bro i have probably had 20 cars since that F11, signature has not been changed.
08-04-2024, 08:21 PM | #13 | |
Rep 10
It is very weird if the mount has cracked again since the car has only been driven 3000km since then by my wife wich drives really slow. They could not see anything when when both cv axles was changed. Will check again. |
08-05-2024, 07:03 AM | #14 | |
Rep 21,553
KurtsM5233.50 |
08-06-2024, 12:23 PM | #16 | |
Rep 10
Partnr: 33212284115 / 33212284116 The ting i discovered today is that the sound does not appear when reversing, i tested i in reverse maybe 20 times today. Only in drive |
08-24-2024, 05:39 PM | #18 | |
Rep 10
First thing we did, retighten the bolt. Did not help. Second thing, got the bolt loose and the diff can be moved slight upwards. Pushed it up and tightened the bolt, noise gone for a couple of days but came back. I think it slowly got down because of the force. Looked at ista for rep guide, it clearly states that the diff should be lowered while tightening. Third thing, new bolt and nut. Followed instructions and the noise is still there, did not help at all. Im really out of ideas on this one... |
M5Rick66675.00 |
08-29-2024, 04:36 AM | #19 | |
Rep 21,553
