06-23-2020, 08:26 PM | #1 |
Rep 126
Drives: 2020 M340i xDrive
Bimmerlink
I bought this app from the pictures and what I have seen that it reads pretty much all values in the dashboard, however I'm mistaken. I don't think they have taken into account we have 2 DMEs so it only reads lambda bank 1, the value confuses me there as I'm use to those readings being between 11-14.7 for the AFR but this reads between 0.9-1.02 circa.
Then we move on to boost pressure, bimmerlink has pictures of it reading boost pressure but my only option is absolute boost pressure so that's already added 14-15psi or 1 bar before we have even started. Could anyone shed some light on this. TIA
335i DCT - Sold
M5 DCT - Sold M140i Top mount big single - RIP M340i xDrive Top Mount big single in the works |
06-25-2020, 01:20 AM | #2 |
Rep 196
The lambda can be easily converter with a lambda calculator, that's what I used. As for the boost pressure reading in bar, I can't say but I agree with you that it's a little confusing. I did a data log and according to the data recorded I was boosting around 30 psi which I know is not correct.
06-25-2020, 05:35 AM | #3 | |
Rep 126
I found a calculator and lambda 1 is 14.7. However it would be handy if I could change the unit value so it reads 14.7 etc Plus is there any app out there that can read lambda 2 I think the developers forget we have 2 DMEs. Is there any option so it can chose a real time boost value? 1.02bar at idle 😂
335i DCT - Sold
07-30-2022, 10:48 PM | #4 |
Rep 123
I know this is an old post but just to clarify for people confused about the absolute boost pressure reading 14psi or 1 bar, that’s because absolute boost pressure considers ambient air pressure which is around 14psi or 1 bar. So basically anything over that is going to be how much boost your making.
