09-05-2018, 08:57 AM | #1 |
Rep 499
Bimmercode - coding mirrors to fold on lock?
Hi guys, I've recently picked up the Bimmercode app and so far have only used it to turn off my ASD.
Is there somewhere in there that will cause the mirrors to fold when I lock the car? I've done some searching and haven't found it but I am still new to coding and probably missed it somewhere lol. Any other "must-do's" in regards to coding through Bimmercode? Thanks |
09-05-2018, 10:19 AM | #2 |
Rep 67
I did all my coding with Carly. I believe they are similar in coding ability. I removed the warnings for nav, added video in motion, trunk close with remote, trunk close with footwell sensor, windows and sunroof close with remote, added turn signal in HUD, and some other small stuff. Good luck.
black_F10M5283.50 Ickdeep5706.00 |
09-05-2018, 02:52 PM | #3 |
Rep 1,107
There is coding through bimmercode to do the mirrors. I coded mine to fold in with the key fob once I hit lock and hold the button for a few sec. Also coded to have the windows and sunroof close and open with the key fob. I have to find the setting though for you.
black_F10M5283.50 |
09-06-2018, 06:40 PM | #4 | |
Rep 499
09-06-2018, 06:43 PM | #5 | |
Rep 1,107
CAS / KOMFORTSCHLIESSUNG_PA = aktiv FRM / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv Also, if you don't want a delay in closing, you also need to code this: CAS->3003 FH MASTER->KMFRT_SCHLIESSEN->Werte=00
09-06-2018, 06:49 PM | #6 | ||||
Rep 499
2016 M5 | Instagram: @black_f10m5
IND cosmetic | M Performance , RKP , 3D Design aero | Eisenmann Race exhaust | AMS catted downpipes | MSR intake | CSF charge coolers | DME Stage 2 tune | KW v3 coilovers | BBS FI | Michelin Pilot Sport 4S |
09-06-2018, 06:51 PM | #7 |
Rep 1,107
Yes, expert mode. You set the value for the delay or how long you have to press the lock to fold the mirrors. If you want it as soon as you hit the lock, then put in wert 00. 1/4 second wert 02.
09-06-2018, 07:00 PM | #8 | ||
Rep 499
09-15-2018, 09:41 PM | #9 |
Rep 19
I did mine with Bimmercode, and was able to do it without going into expert mode. I still haven't even tried that part yet. I don't remember how I did it exactly but it was pretty easy.
I also tried to get the turn signals to show up on the heads up display but even though the Bimmercode said it was coded it still doesn't work for me. I guess I'll have to open up the expert mode to get that one to work.
2016 M5
09-16-2018, 04:59 PM | #10 | |
Rep 1,107
09-16-2018, 05:11 PM | #11 |
Rep 1,107
09-20-2018, 04:02 PM | #12 | |
Rep 384
09-23-2018, 11:21 AM | #13 | |
Rep 19
2016 M5
09-23-2018, 11:23 AM | #14 |
Rep 19
Cool. I generally drive with the non M view, just have that set up for the M2 button where everything is at the max. Day to day I use the non-M HUD view. With the steering wheel position I like I can't see the turn signal display.
2016 M5
05-05-2019, 02:03 PM | #15 |
Rep 74
My mirrors were folding with a long press on the FOB after bimmercoding.
I then entered a wert of 00 in expert mode and they stopped folding. I loaded the backup and they folded with a long press. I am in a 2016 550i drive not an M5 but cannot figure out how to get the mirrors to fold with just a short press on the fob or the comfort access button. |
05-06-2019, 10:54 PM | #16 |
Rep 626
In bimmercode:
Front Electronic Module (FEM-01) Scroll down to MIRRORS Here you will find several options. Good luck
F06 M6 Grand Coupe CP
01-11-2020, 06:02 PM | #17 | |
Rep 124
Drives: 2020 M340i xDrive
Who knows how to code windows up with one touch Thanks again |
01-17-2020, 12:43 PM | #18 |
Rep 145
Going to pick up my CP 2014 M5 today, and downloaded bimmercode and ordered this adapter
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Question, can I run Inpa from my laptop using bluetooth, or do I have get a cable like this one to run PC programs? https://www.amazon.com/OTKEFDI-Enet-.../dp/B07XND685R Coming from an 06 I'm way behind the curve on the F10s. |
