      08-14-2018, 06:49 AM   #1
vanilla.j_
Drives: Singapore Gray/Venetia Beige
Straight pipe
I have an aftermarket exhaust on my F10 but it's not loud enough. I'm thinking of going straight pipe but don't know if I really need to straight pipe the whole thing or just from the mufflers. Anybody have either setup and can talk about how the drone is? Also any codes that came up? Thank you
      08-14-2018, 12:08 PM   #2
boots
Curve Thrasher
boots's Avatar
623
adding down pipes will surely help you first. straight pipes 2nd
Country run
      08-14-2018, 03:36 PM   #3
Drives: Black M5
Listen to Boots, he's a cool dude.
boots623.00
      08-14-2018, 06:50 PM   #4
vanilla.j_
If going downpipes with cats, would it still be loud or should I consider going catless?
      08-14-2018, 06:56 PM   #5
vanilla.j_
I'll do it! Coming from you man should be sound advice haha. Also your M5 is what made me want an F10 man. Seen an exhaust of your car and YouTube and it was beautiful!
      08-15-2018, 02:17 PM   #6
Drives: Black M5
Yes sir, coming from an E60 M5 with RPi Catless Headers and RPi GT Exhaust, I had to find a way to make the F10 sound just as good as the E60's V10, in order for me to keep the car. If it weren't for the F10 RPi GTM Exhaust I would've gotten rid of the F10 M5 a long long time ago.
      08-15-2018, 08:47 PM   #7
boots
Curve Thrasher
boots's Avatar
623
and your car is still running strong d.
Country run
      08-20-2018, 05:07 PM   #8
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
I’ve ran straight pipes with cats and straight pipes with catless downpipes
With downpipes it’s crazy loud ideally to loud but I like it.. but couldn’t bare with the cold starts so turned that off
Most will probably prefer the sound levels with cats
      08-20-2018, 06:39 PM   #9
Craze
I have catless but find its not loud enough
Is the rpi gtm setup drone free and still get cracks during gearchange??
      08-21-2018, 01:52 PM   #10
straightpipeguru
Drives: F13 M6
A catless DP with the RPI GTM would take it to the insane level. some drone at around 1800 rpm but no one really drives at that rpm. cracks and pows during gear change for sure
      08-22-2018, 05:47 PM   #11
boots
Curve Thrasher
boots's Avatar
623
it's not that bad w that set up. I love mine and zero complaints from my wife
Country run
      09-25-2018, 12:46 PM   #12
straightpipeguru
Drives: F13 M6
zero complain from the wife is awesome !!!!
boots623.00
      09-30-2018, 05:19 AM   #13
theinfamousdrew
I'm The Captain Now
theinfamousdrew's Avatar
501
Drives: X5M/X7
Curious to know what exhaust you already have on it? I have the Turner straight pipes which is just a muffler replacement. I love the sound and not a lot of drone.
Turn on. Tune in. Drop out.
IG: @InfamousCarGuy
      10-05-2018, 06:32 AM   #14
boots
Curve Thrasher
boots's Avatar
623
I'm using rpi dp and straight pipes.
Country run
      10-05-2018, 07:03 AM   #15
Craze
Ive got catless downpipes and stock exhaust
I put comp mufflers one rear and it didn't change much
Is removing resonators going to make it much louder?
      10-06-2018, 08:59 AM   #16
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Louder but more drone.
      10-20-2018, 10:51 AM   #17
VETTEPRO
Drives: 2021 X5M Comp, Grigio Telesto
I have CP exhaust. I cut out the top rear section of the muffler and pulled out all the packing. Then I made a sheet metal plate and formed it around the section of pipe that has all the holes in it. I welded that in place and then welded the top section of the muffler back on. Just the top half has the holes covered. I can't get to the bottom of the pipe without cutting out the bottom of the muffler.
It sounds great with no drone. Definitely louder and more "crackly" than stock.
I also cut out a resonator and found absolutely nothing inside. It's just a straight through pipe with no holes or anything, so I just welded it back in. I don't see how a straight pipe would change anything.
Maybe the standard exhaust has vent holes inside the resonators but the CP resonators definitely do not.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers
WWW.AACORVETTE.COM
      10-20-2018, 03:50 PM   #18
jpchavarriaga
Drives: white 2013 f10 m5
Post keep mufflers on
whatever you do avoid deleting mufflers, the drone between 1500-2000rpm is terrible!
      10-20-2018, 06:41 PM   #19
boots
Curve Thrasher
boots's Avatar
623
perhaps on your car but not mine.
Country run
      10-24-2018, 07:28 AM   #20
straightpipeguru
Drives: F13 M6
yup! drone is all relative anyway...
RPi catless DP and GTM FTW!!!
