04-24-2020, 03:28 PM | #1 |
Rep 1,847
Creaking from the front right suspension
The car has just developed a really loud creaking sound from the front right suspension, its really loud when turning the steering wheel and you can also hear it when the car drives over bumps.
The noise is a bit quieter when the wheel is in the air (car on a jack) I sounds like one of the rubber bushes but not sure which one as there are quite a few. I have spoken with BMW assist who said nothing should be lubricated so it will be a failed component and i will have to wait until the lock down ends which is fine as i don't need to use it. Not concerned as the car has an extended warranty but would be interested to hear your thoughts as to what it is. Car has covered 16,500 miles and is a 2016 build. |
04-25-2020, 03:30 AM | #3 | |
Rep 226
04-25-2020, 06:34 AM | #4 |
Rep 19,577
Lots of things can cause creaks but as the car has only 16k on it it's unlikely to be suspension bushes/arms unless specific to CP. More likely creaking can be attributed to strut failure or cracking there. Any play in arms or bushes would be picked up on MOT.
OneExtra810.50 |
04-25-2020, 09:31 AM | #5 | |
Rep 948
OneExtra810.50 |
04-26-2020, 05:43 AM | #6 |
Rep 1,847
05-12-2020, 03:28 AM | #9 |
Rep 1,847
The car is booked in on the 26th May, they are also doing engine oil, filter, microfilter and rear dif oil. £115 Labour only
Its only covered 3,100 miles in 12 months but I wont hurt and should show its been cared for |
05-12-2020, 05:05 AM | #10 |
Rep 19,577
05-12-2020, 06:51 AM | #11 |
Rep 1,847
05-12-2020, 07:24 AM | #12 |
Rep 19,577
That figures then.
*My oil change is due on 21st May and it's done around 3000 miles since this time last year. I'm a bit worried about taking it in when dealer eventually opens because of this Covid situation but don't want to attempt it myself. I guess I'll take plenty of wipes and latex gloves giving it a good wipe down afterwards. |
05-12-2020, 07:25 AM | #13 | |
Rep 948
Don't listen to me though, I know nothing. |
OneExtra810.50 |
05-12-2020, 08:26 AM | #14 | |
Rep 19,577
05-26-2020, 06:33 AM | #16 |
Rep 1,847
Took the car to BMW today so they can investigate. On driving to the dealer the creaking has now turned into a constant tapping/banging/knocking with less of a creak
It literally drives down the road and all you can hear is a quick knock knock knock I have a 420i X Drive as a loan car. 4WD is interesting but not pushed it that hard. |
05-26-2020, 08:58 AM | #17 | |
Rep 19,577
05-26-2020, 09:00 AM | #18 |
Rep 1,847
About 20 miles so not too bad
05-26-2020, 09:18 AM | #19 |
Rep 226
05-26-2020, 09:57 AM | #20 |
Rep 1,847
Yes will do
05-28-2020, 06:28 AM | #21 | |
Rep 1,847
05-28-2020, 07:14 AM | #22 | |
Rep 948
That's if it's the forward arm, there are a few others also. Last edited by Dwaynos; 05-28-2020 at 07:19 AM.. |
OneExtra810.50 |
